09-05-2026, 02:51 PM
I still remember unlocking Courier Tipp and Courier Pill after the Bellhart Quest Board. I thought I was signing up for a few gentle fetch tasks. Instead, I got a crash course in fear, momentum, and fragile cargo.
The delivery quests in Hollow Knight: Silksong are not just side activities. They are a test of how well you understand Hornet's movement. The moment I took my first bundle of supplies, the game removed fast travel and added an item health bar. One hit? Lose a segment. A bad fall? Lose a segment. Slam into a wall without stopping? Lose another. I learned very quickly that fighting was not the answer. There is no easy way to cheat by clearing enemies ahead of time either; the game wants you to move, not fight.
![[Image: 6a9b5e5747740122355dad38UONAY20507]](https://seogc.fp.ps.netease.com/file/6a9b5e5747740122355dad38UONAY20507)
The Delivery Economy
Most of the deliveries you see from Tipp and Pill are repeatable. They are essentially a non-combat way to farm Rosaries ?. That sounds nice at first because you can run them as often as you want for spending money. But after my third trip through hostile bug territory with a bundle of supplies, I realized these are far from the most efficient Rosary farm available. Still, they taught me Hornet's faster movement better than most boss fights.
The standard supply runs also give you a rough idea of difficulty based on their reward. I started with the easier ones near Bone Bottom and Pilgrim's Rest, using the Drifter's cloak to hug the walls and jet streams. It was not glamorous, but it kept the cargo safe.
![[Image: 6a9b5e648e62c1c3e0c2177aHE4AmqG807]](https://seogc.fp.ps.netease.com/file/6a9b5e648e62c1c3e0c2177aHE4AmqG807)
The One-Time Runs That Matter
Beyond the repeatable deliveries, Tipp and Pill offer two serious one-time missions. The first, 'Queen's Egg,' unlocks after you complete any single delivery beforehand. They ask you to carry one Queen Silkeater grub egg to Styx at the far end of the Sinner's Road. I made the mistake of trying this early. The journey was long, but the reward changed my playthrough: 120 Rosaries and a permanent upgrade to my Silkeater farm. After that, every visit to Hornet's well-meaning ally gave me double the usual amount. In the long run, that was more valuable than any single payout.
The other one-time mission is tied to 'Great Taste of Pharloom.' This one asks you to bring perishable ingredients to Loyal Mergwin in the Citadel under a set time limit ⏱️. The item itself then leads into the wish for Hornet's second nail upgrade. If you care about combat, you need this run. If you hate timed cargo, you will still do it for that nail.
Courier's Rasher Is No Joke
The most infamous delivery is 'Courier's Rasher.' I would not wish it on anyone unprepared. Unlike the standard supply quests, this one has a unique time limit. It requires equal parts speed and safety. I tried it before I had the Clawline and Feydown Cloak abilities, and I failed spectacularly. The moment I returned with those two movement tools, the run felt possible, though still brutal.
The key for 'Courier's Rasher' is knowing the Choral Chambers layout before you even accept the quest. I ran the route several times without the delivery, just learning the map. That saved me from so many timer-related heartbreaks later.
![[Image: 6a9b5e706afb622b17dfa925QbLrw1i107]](https://seogc.fp.ps.netease.com/file/6a9b5e706afb622b17dfa925QbLrw1i107)
Tools, Movement, and the Routes I Learned to Trust
For almost every delivery, my philosophy was: avoid enemies at all costs. For the harder runs, I relied on a few specific tools.
Clawline and Feydown Cloak – Essential for 'Courier's Rasher' and any route with long gaps or vertical climbs.
Flea Brew offensive tool – Gave Hornet extra speed when I needed to burst past enemies.
Silkspeed Anklets – Another speed boost that made a surprising difference on long deliveries.
Compass ? – Not optional for me. It helped me check route progression without opening the full map.
Wanderer's Crest – If you have memory lockets to spare, the downward pogo from this crest is much more consistent for avoiding both enemies and hazards.
Curveclaw – When I did have to fight, ranged damage kept annoying flying enemies from ruining the item health bar.
For the Sinner's Road delivery to Styx, stealth was the answer. The Muckmaggots can be almost entirely avoided if you run along paths without them. I also abused area transitions to despawn aggressive flying enemies. It felt like cheating, but the game allowed it, so I called it strategy.
For 'Courier's Rasher,' I ran the Choral Chambers route multiple times before the real attempt. I recommend that more than any charm or tool. Knowing where the vertical shortcuts are and which platforms are safe at speed is the real reward.
Final Delivery Report
Looking back, the courier quests in Silksong are a strange mix of frustration and satisfaction. They are not the most efficient way to farm Rosaries, and some of them will make you question your sanity. But they force you to master Hornet's movement in a way that combat alone never does. The Queen's Egg upgrade alone makes the courier chain worthwhile, and the second nail upgrade from 'Great Taste of Pharloom' is too good to ignore.
If you are starting these quests now in 2026, my advice is simple. Do the easy standard deliveries first. Learn to avoid enemies instead of fighting them. Do not touch 'Courier's Rasher' until you have Clawline and Feydown Cloak. And for the love of Pharloom, learn the Choral Chambers before the timer starts. Tipp and Pill may act like friendly couriers, but their requests are a trial by fragile cargo.
Whether you are diving into Hornet's adventure for the first time or returning for another punishing playthrough, having the right game at the right price makes the experience all the sweeter. If Silksong is still sitting in your backlog—or if you want to grab a fresh copy for a friend so they can suffer through the courier trials with you—it pays to hunt around for the best game deals before you commit to a full-price purchase. A little patience on the shopping side can free up budget for future titles, letting you focus on mastering those fragile deliveries without any buyer's remorse lingering in the background.
