09-12-2026, 04:14 PM
Listen, I've spent countless hours in Pharloom, dodging spiked balls and getting my silk handed to me by giant bugs. But nothing—and I mean nothing—prepared me for the sheer domestic bliss of owning a Bellhome. It's like finding a warm cup of tea in a hurricane of hostility. So here's my tale of how I became the proud owner of a cozy bell-shaped abode, and how you can too without losing your mind or your Rosaries.
![[Image: 6aa498804d3553e2c1aeda14soRv502T07]](https://seogc.fp.ps.netease.com/file/6aa498804d3553e2c1aeda14soRv502T07)
Unlocking the Bellhome: A Homeowner's Odyssey ?
First things first: you can't just waltz into Bellhart and claim a home. You've got to earn it. Think of it as the world's most dangerous homeowners association. To even start, you need to defeat Widow and complete the Threadspun Town task. That opens up Bellhart, and from there, you'll want to keep exploring Pharloom and returning to the Wish board like a moth to a very quest-heavy flame.
There are three quests you should complete:
Restoration of Bellhart (required)
My Missing Courier (recommended)
My Missing Brother (recommended)
Donating 250 Rosaries kicks off the town's reconstruction. While that's happening, finish those two courier quests—they unlock a courier service that will become your best friend for the Rosary grind ahead. As you build up the town and save its patrons, talk to Pavo. Always make sure he has nothing new to say. Eventually, once you've found more benches and explored more map areas, the construction finishes. If you've been diligent with the Wishes, your next chat with Pavo rewards you with the Bellhome Key.
Your Bellhome is on the third level of the town, above the Pinmaster and Relic Seeker. Use the key, step inside, and bask in the glow of the Resident trophy/achievement. For now, it's just a bed. But oh, the decorating possibilities!
![[Image: 6aa498873626f4c220b7dd34bKqCeOuy07]](https://seogc.fp.ps.netease.com/file/6aa498873626f4c220b7dd34bKqCeOuy07)
Decorating Your Bellhome: Because Even Bug Warriors Need Throw Pillows ?
Once you have the key, head to Frey at the Bellhart general goods store. She sells all the decorations, except the Spa, which requires you to buy two other upgrades first. These items are expensive and serve little practical purpose beyond making your home look fabulous. Here's the full list:
Upgrade
Price
What Is It?
Desk
380 Rosaries
Allows you to read Relics you've turned in to the Relic Seeker.
Gleamlights
320 Rosaries
Lights up the home's interior.
Bell Lacquer
520 Rosaries
Paint the outside of the bellhome: Red, Silver, Black, Yellow, or Blue.
Personal Spa
1,100 Rosaries
Adds a second floor with a hot spring that regenerates Silk and Masks.
Most decorations appear immediately after purchase, but the Bell Lacquer takes time to apply—you can watch the paint dry while you adventure, which is oddly satisfying.
![[Image: 6aa49891e584859bdead6058fj1Pysy907]](https://seogc.fp.ps.netease.com/file/6aa49891e584859bdead6058fj1Pysy907)
Gathering Rosaries Fast: The 45-Minute Money Method ?
Altogether, all upgrades cost a staggering 2,320 Rosaries. That's like trying to teach a Grub to tap dance—daunting but not impossible. The key is the courier service. With Tipp & Pibb's Courier Service unlocked, you can make deliveries that pay very well.
My go-to is the Pilgrim's Rest run, netting about 239 Rosaries every four minutes. You'll need the Silkshot tool (or similar) and the Pollip Pouch. If Pilgrim's Rest isn't available, Bone Bottom is the next best choice, giving 128 Rosaries if you defeat the fishermen on the way. But Pilgrim's Rest is the safest and most lucrative.
Here's my step-by-step route:
Go through Greymoor, taking out the scissor bug in the first room.
Dash right until you reach the room with another scissor bug patrolling above. Destroy him from below if you can.
In the room with the trident bug, use your trap to defeat it quickly. Kill the other bug beyond it before climbing up.
Use your trap in the pilgrims room to take out the first three and last two bugs. You can kill the bellbearer between the pilgrim sets from below.
Dash to Far Fields and fall down on the right side for the first two wind sections.
Switch to the left side and fall gently onto the left side next to the shortcut.
Run to Pilgrim's Rest to drop off the package.
Fall down toward the Bellway Station, but stop by the target practice room to kill both bugs.
Take the Bellway back to Bellhart to repeat as necessary.
![[Image: 6aa49897125f9ca470dde970XLC50x9Z07]](https://seogc.fp.ps.netease.com/file/6aa49897125f9ca470dde970XLC50x9Z07)
With this method, you can afford every upgrade in under 45 minutes. No Rosary Strings, no risk of losing your hard-earned geo—just pure, efficient capitalism. Before you know it, your Bellhome will be the envy of every bug in Pharloom. And honestly? After all those boss fights, you deserve a spa day. ?
If there's one thing a long courier grind teaches you, it's the value of patience and a route you can repeat without thinking—and that instinct has a habit of following you out of Pharloom. Holding off on a purchase until the price finally drops is the real-world version of the same discipline, and it pays off just as reliably.
For anyone who'd rather not sit around refreshing storefronts hoping the number moves, a game price tracker like DealNest does the watching for you, surfacing discounts across stores so you can decide when a title is actually worth the spend. Same efficiency mindset, just pointed at your wallet instead of your Rosary count.
Upgrade
Price
What Is It?
Desk
380 Rosaries
Gleamlights
320 Rosaries
Bell Lacquer
520 Rosaries
Personal Spa
1,100 Rosaries
