Mitchell UltraMate 7.0.481 Sep.2012
[Image: Testing2_2012_11_15_13_09_46.png]
[Image: Testing2_2012_11_17_07_37_28.png]
[Image: Testing2_2012_11_17_07_40_19.png]
[Image: Testing2_2012_11_17_07_42_02.png]
[Image: Testing2_2012_11_17_07_48_00.png]
[Image: Testing2_2012_11_17_07_48_26.png]
[Image: Testing2_2012_11_17_07_48_50.png]
Welcome to the online Help for Mitchell Estimating version 7.0. Mitchell Estimating is industry's most complete estimating solution for insurance companies, fleet companies, repair facilities, and independent adjusters. With the most comprehensive database in the industry, Mitchell Estimating generates quick, complete, and accurate estimates in minutes.
Mitchell Estimating includes all you need for data entry, estimate calculation, reporting, and system administration. With the administration functions you can customize the system to better fit your business. Mitchell Estimating also offers a number of value-added options to extend the functionality of the program to further serve your specific needs.
Mitchell Estimating provides a practical means to obtain regular updates to the industry-standard Mitchell Collision Estimating database and Replacement Assemblies Estimating Guide. All Original Equipment Manufacturers (OEM) part prices and labor, as well as replacement assemblies labor information are supplied with Mitchell Estimating.
Mitchell Estimating is designed to help your business run more efficiently by providing you a quick and reliable way to consistently generate estimates. With its industry-standard database, you can create complete estimates in minutes. Mitchell Estimating and the Windows environment provide a user-friendly system that automates most of the estimating process.
Quote:size : 4.33 GB
pass: is also on zip file
Expiration date: 31 Dec.,2012
Note:
in case of using after the above date , recommend to set time before that date.
Enjoy All!
Mitchell UltraMate 7.0.481 Sep.2012.zip
Downloaded: 12 times
[Image: Alcoholahmed.png]
Mitchell Ultramate 2012 PATCH
Use the PATCH below to avoide expire date .
Simply install the program , and apply the PATCH ..
Login Details :
Username: mitchell
Password: mitchell
Enjoy !!!
Mitchell Ultramate 2012 PATCH.txt
Downloaded: 7 times
Hi, pass please, thanks
