Bosch ESI[tronic] 2.0 Trucks [03.2013]
Bosch-logo
Diagnostics Software
1st WEB Release
Version: 2.0
Type: Diagnostics Software
Language: English, Spanish, Italian, German, French, Dutch, Portugese (MULTI)
OS: WinXP, Vista , Windows 7
Format: ISO
Update: 03.2013
Overview ESI[tronic] 2.0 Software:
The increasing amount of electronics in todays vehicles means that simple maintenance work will soon no longer be
able to be carried out without enhanced control unit diagnosis:
• Automobile manufacturers recommend the review of all faults stored, during routine maintenance.
• The workshop requires a device for programming the service interval display and even for work which was once
purely mechanical.
• Brake control systems such as ABS, TCS and ESP require activation of the solenoid valves in various high-pressure
pumps when bleeding the brake hydraulic system or changing the brake fluid.
ESI[tronic] 2.0 is the new PC-based diagnostic application software that is released along with the M-VCI scan tool.
ESI[tronic] 2.0 provides the European vehicle coverage that is currently lacking with the M-VCI scan tool making it a
complete scan tool with coverage for European, Domestic and Asian (including Korean) vehicles.
ESI[tronic] 2.0 provides a comprehensive coverage of the market in the daily business. The data is constantly updated
to make sure that you can service new vehicles without any problems.
ESI[tronic] 2.0 2013/3 Features:
• Free one year diagnostic software subscription
• Quick module status check of the vehicle network
• Intuitive system menus to speed diagnostics
• Pulls OBD II codes with 4 clicks!
• Includes European, Domestic and Asian vehicle coverage
• Wide range of functions such as:*
  – Auto Brake Bleed Test
  – Bi-directional controls for engine, body and chassis systems
  – Steering Wheel Angle Reset–– Maintenance Light Reset
  – Electronic Stability Control Test
  – Electronic Throttle Programming
  – Tire Pressure Sensor ID Programming
• Technical support for tester operations via technical hotline
Bosch ESI[tronic] 2.0 Trucks [03.2013] TORRENT.rar
ESI[tronic] 2.0_News.pdf
File Type: .pdf
how to activate it?
[Image: 15ryt12.gif]
Bosch-logo Bosch ESI[tronic] 2.0 + Trucks [02.2015] Admin 2 11,572 09-04-2015, 04:07 PM
Bosch-logo Bosch ESI [tronic] 2013 + UPDATES [OFFICIAL TOPIC] Admin 7 20,838 05-16-2015, 03:32 AM
Last Post: m-power
