Scania XCom 2.27.2.1 [2014]
Saab
[Image: v592kw.jpg]
[Image: v2vhg1.jpg]
Year / Date of Release: 2014
Version: 2.27.2.1
System requirements: Windows 7 x86 (32bit)
Medicine: Present
Scania XCOM 2.27 - a diagnostic program to read, save and edit data ECU, such as error codes, parameters, statistics, etc. using the interface scania vci2 or scania VCI3, which is used to connect to the ECU protocol CAN.
Supported data ECU modification of the following types:
EMS - Engine Management System.
GMS - transmission control.
RET - retarder system.
AWD - all wheel drive system.
CLS - clutch.
EEC - to reduce emissions.
COO (COO7) - Coordinator.
BWS (BCI1) - Body System.
Supported resolutions fault codes in the text description of the following types:
EMS (S6, S7, S8).
GMS (OPC4, OPC5).
RET (RET1, RET2).
AWD (AWD1).
EEC (SCR1, EEC3).
COO (CoO6, COO7).
HMS (HMS1).
Functions:
AdBlue ON / OFF.
EGR ON / OFF.
The chassis ID / VIN Change.
Alarm ON / OFF.
Raising horses
Restoring ECU.
Reset ECU.
Unlocking the ECU without a PIN
Extras. information:
On XP did not work!
On x64 will not work emulator key!
On Vista / 8 / 8.1 not tested.
Compatible with [Image: 282kbc.png]
Scania XCom 2.27.2.1 [2014].zip
Downloaded: 14 times
Thanks given by: alcoholahmed , tsbrianesi
Scania Scania XCOM 2.27.1.2 + Dongle Emulator Thunder 0 4,173 08-30-2016, 12:29 AM
Scania Scania XCOM V 2.27.1.2 roquero85 0 2,695 02-08-2015, 09:34 AM
Last Post: roquero85
