Mercedes DAS Xentry + WIS [2014 - 2015] VMware
[Image: 155tbn6.jpg]
[Image: 2zo9obl.png]
The program Mercedes DAS Xentry - designed for fault diagnosis of electronic systems and units of cars, a Mercedes and used in conjunction with a scanner dealer Star Diagnosis. The interface of the program Mercedes DAS Xentry has a multilingual interface, including the Russian language. With the help of the program and the diagnostic adapter can diagnose cars, commercial, trucks and buses produced by Mercedes 1989 model year. Diagnostics with the help of this program will identify malfunctions of electronic engine management systems, automatic transmission, security, air conditioning, ABS, EDS, ESP, cruise control and many other systems assistants.
Database Mercedes WIS NET net contains the full information on repair (descriptions of operations, electrical, etc.), services, labor hours (ASRA) all cars Mercedes, including trucks, buses and specials. technique. Comes Mercedes WIS net 3 DVD DL. Requires a full installation program on the hard disk.
Mercedes WIS dealer information base contains information on repair, maintenance, diagnostics, body repair, wiring diagrams and bodywork (ASRA) for all cars Mercedes-Benz, trucks, buses and specials. technique, in all markets. Mercedes WIS comes on 2 DVD. Mercedes-Benz Wis contains the full version (about eight languages, including Russian). Most of the additional languages ​​is only available for the menus and new documents.
Mercedes WIS contains detailed instructions for installation, dismantling, disassembly, assembly, adjustment and configuration of the various components and assemblies, as well presented wirings (electrical) connector pinout, body size and body repair manuals.
The program Mercedes WIS contains detailed information on repair of mechanical and automatic transmissions Mercedes. This program is indispensable for services and service stations Mercedes-Benz.
Module "ASRA" is an integral part of the application. ASRA - an abbreviation of Arbeitstexte, Standardtexte, Richtzeiten und Arbeitswerte (job descriptions, standard descriptions, specifications and labor times). The company Daimler AG has created a list of works produced in the STOA. These works have a description and unit of account of work that differ for Germany / Austria (disambiguation AW) and other countries (labor times). ASRA is an electronic catalog of standards of work that provides a quick search of work and the time of their execution. Defined using ASRA data are the basis for the creation of repair orders and invoices.
Mercedes DAS Xentry + WIS [2014 - 2015] VMware.zip
Downloaded: 27 times
If It’s Not Broken – Don’t Fix ItDrive
Mercedes Mercedes DAS/XENTRY 12/2015 [12/2015] jahacmm 0 3,220 12-07-2015, 06:34 AM
Last Post: jahacmm
Mercedes DAS XENTRY OPEN SHELL 12/2014 - 1-2/2015 jahacmm 0 4,971 09-23-2015, 05:38 AM
Last Post: jahacmm
Mercedes Mercedes DAS/XENTRY 09/2015 jahacmm 0 2,575 09-15-2015, 05:07 AM
Last Post: jahacmm
Mercedes Mercedes DAS Xentry SD [03.2015] alcoholahmed 0 2,584 03-18-2015, 05:23 AM
Last Post: alcoholahmed
