Cummins INSITE 7.6 [2013]
Cummins
Diagnostic software for Cummins engines and ECM units
[Image: 33yl44o.gif]
[Image: atrr4h.gif]
[Image: wvsgo7.gif]
Cummins INSITE is a PC-based software application that provides quick and easy access to your engine's electronic performance information, which enables faster service turnaround times. INSITE helps to ensure accurate procedures and diagnosis and limit downtime, while increasing productivity and profits.
Cummins INSITE software supplies engine information quickly, getting the inside details you need. No matter what kind of equipment you run, INSITE is the one support product to have in your virtual toolbox to fit every Cummins electronic engine.
Cummins INSITE can provide your business with:
Trip and vehicle information
Parameter and feature adjustment
Accurate problem diagnosis
Complete wiring diagramsand sensor location maps
Step-by-step trouble-shooting information
Fault tree information
Fault code and symptom-based diagnostics
Engine diagnostic tests
Tools to create templates for a group of vehicles
Fleet management/driver reward programs
Audit trail information
Enhanced ECM security
Cummins INSITE is offered in four functional levels: Basic, Lite, RSGR and Pro, ranging from a read only access level to full-function access and capability for the service professional.
NEW INSITE FEATURES
- Installation upgrade capability - upgrade from previous versions
 of INSITE 7.2, 7.3, 7.3 FP1, and 7.3 FP2
- INLINE 4/5 drivers installation
 The latest available INLINE 4/5 drivers will automatically be installed
 or upgraded with the   installation of INSITE v7.4.  Administrative
 rights are needed for the USB driver association after the installation.
- INSITE Fault Viewer
 INSITE Fault Viewer
 will be available for installation through INSITE DVD for all registered
 INSITE Pro Functionality users.  INSITE Fault Viewer is designed to
 provide the ability to monitor public faults on a J1939 or J1708 network.
 The Fault Viewer will help to isolate the probable cause of a system
 failure or error. Administrative rights are needed for installation.
- Operating System Support
 Windows XP 64 bit, Vista 64-bit, Windows 7 32-bit and 64-bit are now
 supported. Windows 2000 is NO longer supported. See Operating System
 Support section below for more details.
NEW Engines Support
- QSB 4.5/6.7 CM2250
- QSL 9 CM2250
New INSITE Base Features
- Data Monitor/Logger Graphical Monitoring
Graphical Monitoring is a way to display, log, print, and save data for up to six parameters in a graph. Graphical Monitoring visually monitors and plots multiple parameters into a graphical display.
- Ability to add Functionality Password when opening INSITE for the first time
INSITE now provides the capability to enter both the Basic and Functionality password the first time it is opened.  This applies to a new installation. After entering the Basic password, a window will open asking for the Functionality password to be entered.
- Export All Work Orders
All Work Order images can be exported using the right-click menu and selecting the ‘Export All Images’ option.
- Single key off for multi-module downloads
INSITE only requires a single key off at the end of a multi-module calibration download. All ECM Codes to be downloaded can be selected before the calibration download begins.
- Adjustable Parameters Recovery File
If a calibration download fails when Save/Restore Adjustable Parameters is selected, INSITE will save these parameters to an Adjustable Parameter Recovery File.  The file can be used by INSITE to restore the Dataplate and adjustable parameters on this ECM if it is in a ROM Booted or Foot Printed state on the next successful download.
Languages Supported:
 - English
 Limited Translation:
 - Chinese (Simplified)
 - Danish
 - Dutch
 - Finnish
 - French
 - German
 - Indonesian
 - Italian
 - Japanese
 - Korean
 - NOrwegian
 - Portuguese
 - Russian
 - Spanish
 - Swedish
 - Turkish
COMPONENT REQUIREMENTS (for minimum performance)
Platform: IBM or 100% Compatible
Operating System: Supported: Windows XP SP2 or greater, Vista, and Windows 7     32- and 64-bit versions for all operating systems
Processor: XP - 500 MHz
Vista - 1 GHz
Windows 7 - 1 GHz
RAM Memory: XP - 512 MB
Vista - 1GB
Windows 7 - 2GB
Hard Drive: 2 GB available disk space
Media Device: DVD-ROM (may be internal or external as needed for installation)
Display: SVGA(1024 x 768 pixels) CRT
LCD: TFT Active Matrix, XGA (1024 x 768)
Keyboard: 101 Key Enhanced
Pointing Device: WindowsTM Compatible Device
Multimedia: Any Windows Compatible Sound Device
Other Software: Adobe Acrobat Reader v7.0 or higher
                       Microsoft .NET Framework v2.0
Printer: Windows Compatible Device
Internet connection: None
Cummins INSITE 7.6 [2013].zip
Downloaded: 28 times
Thanks given by: Admin , Bycom2003 , roquero85
  Cummins Insite 9.0.1. 8.7 + Cummins Incal (without pass) motorstate 1 9,222 08-23-2022, 08:37 PM
3 Guest(s)
