Porsche PIWIS Tester v32
![[Image: 2E3mN.jpg]](http://i.imgur.com/2E3mN.jpg)
PIWIS is the latest inspection equipment of the Porsche Company. Original Tester for Porsche, support Diagnosis/Programming/Coding/Key Programming. The PIWIS Tester is a modular, portable diagnostic, information, and measuring system
The unit contains a computer, hard disk with installed software, LCD display, and a Lithium-ion battery. A virtual keyboard and a USB mouse is available for operation in addition to the tracer pin for the LCD touch screen. Data and measured values can be printed using the USB-interface with an external printer. The LCD display is used as the display. An external monitor can also be connected.
It can read codes, clear codes for all type of Porsche vehicles. It also could test, program & guard against theft according to its data flow.
It could lead to malfunction self-inspect and full car circuit diagram for the car which was made after 2005.
It also has the function of measuring leads for multi-meter.
It's the essential equipment for Porsche vehicle technicians.
Porsche PIWIS Other Features:
Laptop based PIWIS Tester for Porsche, supports Diagnosis/Programming/Coding/Key Programming
The PIWIS Tester is a modular, portable diagnostic, information, and measuring system.
Configuration:
Configuration:
1. PIWIS Tester
2. Power pack 90/264 VAC
3. Power cord for power pack
4. OBD Porsche Diagnostics cable
5. Cables for the multimeter(for future expasion)
6. USB cable
7. Black ground cable with terminal
8.2 red probe tips
9. Y-connection piece to connect the PIWIS Tester and the DVD drive to the power pack
10.2 tracer pins
11.3 fuses (5 AF)
12. Case
13. External DVD driver (USB)
14. Diagnostics adapter cable(26-pin to 8 pin)
15. Test connector for OBD Porsche diagnosis lines and adapter socket for OBD Porsche diagnostics cableTORRENT FILE| Single Extraction | Real Screen Shots
