FOCOM 1.0.12194
HELLO,
FOCOM 1.0.12194
Read identification
Displays complete identification of control unit, e.g. part number, software/hardware version, manufacturer, etc...
Read fault codes
Displays all stored and pending fault codes with complete description (e.g. "Rail pressure - too low pressure").
Program supports report printing or copy to clipboard.
Clear fault codes
This function clears all stored fault codes and other diagnostic information.
Auto-scan (complete car scan/test)
Detects all Ford ECUs (electronic control units) installed in car and reads all diagnostic fault codes.
Measured Values
Program displays live Data like Engine Speed, Battery voltage, Oxygen Sensor, Coolant Temperature, etc. Values can be displayed in graph, 9 values at once, or full listing (all measured values). Logging to file is also supported, which allows offline analysis.
Actuator test
Actuator test activates particular actuator (e.g. turn on fuel pump, lock/unlock wheel, lock/unlock doors, cut off fuel, etc..)
Programming functions/Adaptation
This feature is of great importance in all vehicles because systems like Engine control units, Immobilizers, Airbags, Alarms, Body Control Units, and some others, require you to perform reset or programming procedures after car repair is done, or even configuration after replacing broken Control Unit.
[Image: 1qlpia.jpg]
Fing32
FOCOM.txt
Thanks given by: Admin , bordom
Ford FoCOM v1.0.12194 Multilanguage Thunder 0 3,320 04-01-2017, 02:08 AM
Ford FoCOM v1.0.12194 Thunder 0 2,380 08-18-2015, 12:56 AM
