TORQUE PRO 1.8.54 for Android + Extra Plugins
[Image: torque_pro_1.png]
Android | 58 MB
See what your car is doing in realtime, get OBD fault codes, car performance, sensor data and more!
Torque is a vehicle / car performance / diagnostics tool and scanner that uses an OBD II Bluetooth adapter to connect to your OBD2 engine management / ECU
Layout your own dashboard with the widgets / gauges you want!
It can use the GPS to provide tracker logs with OBD engine logging so you can see what you were doing at any point in time
It can also show and reset a DTC / CEL / fault code like a scantool. Helps you fix your car and helps keep repair costs down!
Homepage -
http://torque-bhp.com
Requirements:
- O.S.: Android 1.6 or higher
- Bluetooth OBD2 adapter
TORQUE PRO 1.8.54 for Android + Extra Plugins.txt
