Conflict between Tecdoc and Renault consult
Hello, know anyone knows how to fix the problem that occurs when we install both Renault Consult and Tecdoc? i try ti register two .ocx but now i recive a error in tecdoc when i want to see a picture : Error number 35
what tecdoc version ?
04/2011 and consult 03/2011
(10-10-2011, 02:21 AM)robocoop Wrote: 04/2011 and consult 03/2011
last version tecdoc, working with consult 03/11 - 02/2011
this is Acrobat reader problem Smile
(10-10-2011, 04:49 PM)Admin Wrote: this is Acrobat reader problem Smile
What do you mean? what version acrobat reader does not allow working consult or tecdoc? Leadtools not using in Acrobat Reader ( L****13n.dll) !
after register Vcf132.ocx and ltocx13n.ocx renault work but in tecdoc the picture don`t work, i recive error 35
I´m whith the same problem. If you install Tecdoc after Renault, you can see Tecdoc pictures but not Renault pictures. If you install Renault after Tecdoc, you can see Renault pictures but not Tecdoc pictures.
What could we do?
I'm with the same problem!
Have you solved it?
Best regards
