Doosan Data Monitoring System (DMS-3) v1.41 English
Doosan
[Image: doosan_logo.jpg]
Win | 71 MB
The Doosan Excavator/Wheel Loader Monitoring Program (also called “DMS-3”) offers the following functions by connecting Controller (EPOS or VCU) with the user’s IBM PC compatible PC.
1. Monitoring: You can monitor the current status of equipment installed with Controller (EPOS or VCU).
2. Graph Output: The major excavator/Wheel Loader sensor data will be displayed in a graph format. The data can be saved in the hard disk. You can check the excavator/Wheel Loader’s performance through data comparison and analysis.
3. Force Operation: You can use vehicle diagnosis by forcing Controller (EPOS or VCU) outputs.
4. Diagnosis: You can check the real-time and past malfunction history maintained by Controller (EPOS or VCU).
5. History Data: You can analyze the work patterns when using an excavator/Wheel Loader, by checking the operation hours, filter/oil information, and daily operation information.
6. Parameter change protected with code: 18772 (change factory settings). Codes for rpm change/force operation and flash epos: 11830 and/or 18675.
Hardware connection: A separate communication cable is required to establish communication between Controller (EPOS or VCU). and external PC. The communication cable should be connected to the excavator/Wheel Loader’s maintenance connector and user PC’s Serial port.
Homepage -
http://www.doosan.com
Requirements:
- Hard Drive: 100 MB of available space
- CD-ROM
Doosan Data Monitoring System (DMS-3) v1.41 English.txt
Doosan Doosan EDIA/e-Doctor v2.3.2.3 English + Training Thunder 0 3,656 01-01-2016, 05:25 AM
Doosan Doosan Solar Monitoring System V 3.O roquero85 0 3,135 02-22-2015, 11:01 AM
Last Post: roquero85
