Xentry OpenShell XDOS Patcher 2.0
Disable UAC settings Before run Patcher:
Disable UAC settings to "Never notify" -> Restart system -> Apply Patch or Undo -> Then, you could return UAC settings back.
It`s better to DISABLE idiotic Windows Defender too.
Patcher automatically detect system OS Type 64-bit or 86-bit .
How to use XENTRY OPENSHELL Patcher:
Quote:1- Close Starkey Center
2- Run xentry Patcher , Patcher will run automatically as  Administrator
3- Click on Patch Starkeycenter
4- Click on Patch XENTRY Activations
5- Click on FIX XENTRY Activations
6- Close Patcher
7- Run Starkey Center and Use Old Keygen for Xentry and DAS And WIS
Whats's New!
Xentry:
Add Patch Missing Pictures fix 2015
DAS Standalone:
Add Fix No DAS Key & Timeout fix Required
Add DAS Standalone 7.7.0 & Shortcut to Desktop
Add Switch DAS To SD Connect C3
Add Switch DAS To SD Connect C4
SD Connect Switcher:
Add Switch ToolKit To SD Connect C3
Add Switch ToolKit To SD Connect C4
Note :
  When you activate program the first time,
  must provide the Internet connection on device to be activated successfully,
  after activate program you can use it without Internet
How Install WIS Standalone:
You must provide (2) partition on Disc
C:\ & D:\
Change Drive Letter for partition D:\ To E:\ Then Click patch WIS STANDALONE
Arrow Post your Hardware ID to get your License KEY !!!
Direct Download | Single Extraction | Real Screen Shots
XNTYPTCR20.zip
Downloaded: 103 times
my hardware Id: BAD0F-208FF-68D70-D3A3A-77500-4C5DE-4ED55-CCF04
Thanks given by: RustyDert , Ve1ya
(06-17-2016, 11:01 PM)kesag Wrote: my hardware Id: BAD0F-208FF-68D70-D3A3A-77500-4C5DE-4ED55-CCF04
Key: N28JKBcwnaV=kGsLPa5y9MK9z1+bvZ4nQ47Pf7AI6q96ANY+TVpKnl1z16xZafewTQT9JF65Aae08H6fcnYmrRswAKDYu7MTLSiJajnAa1FLQpEERQl3rBy7d3G2
9146F-208CC-2FB1A-17E96-01760-4C50B-DE3A3-8CF04 thanks
(07-16-2020, 07:58 PM)RustyDert Wrote: 9146F-208CC-2FB1A-17E96-01760-4C50B-DE3A3-8CF04 thanks
Key: J4A6bMn2Zslip+KDtSy3uMqYRWeAX+ApWFdwIxn1neMpaMGn5KmWVCI6POmzdl+=1=nf4KNdjr4EUYhJEQW5wm3+pyKiMR8tb5+KHJulF7Z+MDnLsmsyDz7JGWn+
88E6F-208CC-2FB1A-17E96-01763-9680B-DE3A3-8CF04 pleas one more thanks
(07-30-2020, 08:38 AM)RustyDert Wrote: 88E6F-208CC-2FB1A-17E96-01763-9680B-DE3A3-8CF04 ještě jednou díky   Blush
(06-17-2016, 11:01 PM)rustydert Wrote: moje ID hardwaru:
88E6F-208CC-2FB1A-17E96-01763-9680B-DE3A3-8CF04 ještě jednou díky   [Image: blush.gif]
Key: J5I6bMn2Zslip+KDtVsguMqYRWeAuZeM3afM26O4ul5+etZpCsy4PCBOPPKLfcv6KiceaABp7yktofETiTXEoGJVgSO4kNVEq7Ax3Wc+6qi1fPiJ=v+8f7=mClAu
HWID:
BE1AF-20869-3AD70-DB7F2-A1270-4C598-12AF8-A1ABE thx
Mercedes Mercedes DAS XENTRY OpenShell XDOS 31.8.2.0 [06.2022] Admin 0 3,032 06-01-2022, 04:58 AM
Mercedes Mercedes DAS XENTRY OpenShell XDOS 30.8.2.1 [12.2021] Admin 0 3,679 11-29-2021, 06:51 AM
Mercedes Mercedes DAS XENTRY OpenShell XDOS 29.8.2.2 [09.2021] Admin 0 4,963 09-07-2021, 06:00 AM
Mercedes Mercedes DAS XENTRY OpenShell XDOS 28.9.3.2 [03.2021] Admin 0 4,708 03-18-2021, 11:41 AM
Mercedes Mercedes DAS XENTRY OpenShell XDOS 28.9.2.3 [12.2020] Admin 0 4,335 02-28-2021, 05:33 AM
Mercedes Mercedes DAS XENTRY OpenShell XDOS 27.15.2.3 [09.2020] Admin 0 4,203 08-06-2020, 05:38 AM
Mercedes Mercedes DAS XENTRY OpenShell XDOS 26.9.3.2 [03.2020] Admin 0 5,560 03-24-2020, 07:03 AM
Mercedes Mercedes DAS XENTRY OpenShell XDOS 19.12.6 [12.2019] Admin 0 3,531 11-27-2019, 05:55 AM
Mercedes Mercedes DAS XENTRY OpenShell XDOS 25.15.2.3 [09.2019] Admin 0 5,295 08-20-2019, 04:34 AM
Mercedes Mercedes DAS XENTRY OpenShell XDOS 25.15.2.1 [07.2019] Admin 0 2,927 07-13-2019, 04:46 AM
