AUDI, JETTA, PASSAT, 09G/09M Automatic Transmission Repair Manual
ELSAWin
[Image: images?q=tbn%3AANd9GcSGs92C68wSsIX8OvxHh...w&usqp=CAU]
AUDI, VW JETTA, VW PASSAT, 09G/09M Automatic Transmission Repair Manual. This manual contains the procedures necessary to diagnose, rebuild and or repair the 09G/09M transaxle and is intended for automotive technicians that are familiar with the operation of automatic transmissions.
The Japanese company AISIN Co., LTD is the manufacturer and developer of the Front Wheel Drive TF60SN transaxle, which is a 6 speed, fully automatic and electronic controlled transaxle. Volkswagen engineers were also involved, in conjunction with Aisin, in the development process for their vehicles and they gave it the 09G/09M designation. BMW gave it the designation 6F21WA for their Mini-Cooper.
The 09G/09M transaxle is used in a wide variety of applications and engine sizes. As a result, the number of friction plates, planetary ratios, intermediate ratios and final drive ratios will vary depending on torque load requirements of the specific vehicle. The TF60SN transaxle uses a gear ratio sensitive system, requiring the correct transaxle interchange. The TF60-SN is used in the BMW Mini Cooper, Volkswagen and Audi vehicles. This transaxle is referred to as the TF60-SN, 09G, 09M, 6F21WA and in some overseas vehicles as 09K. As a result there are a variety of different case and part configurations. Some of these units have the heat exchanger attached to the transmission while others use a remote heat exchanger. This alters the case, case cover and the valve body and if incorrect parts are used, severe planetary failure will occur. This manual covers these differences so that this mistake will not happen to you.
The 09G/09M transaxle uses a Lepelletier arrangement, using a simple planetary coupled with a Ravigneaux planetary. This arrangement makes six forward speeds and reverse possible, with only five clutch packs and one freewheel.
Contents:
   COMPONENT APPLICATION CHART
   IDENTIFICATION TAG LOCATION AND INFORMATION
   SPEED SENSOR INFORMATION
   PRESSURE SWITCH AND FLUID TEMPERATURE SENSOR INFORMATION
   SOLENOID LOCATIONS AND IDENTIFICATION
   INDIVIDUAL SOLENOID FUNCTION AND FAILURE RESULT
   SOLENOID OPERATION
   SOLENOID APPLICATION CHART
   PASS-THRU CASE CONNECTORS AND WIRE HARNESS
   CASE CONNECTOR TERMINAL IDENTIFICATION
   CASE CONNECTOR INTERNAL COMPONENT RESISTANCE CHARTS
   TCM CONNECTOR INTERNAL COMPONENT RESISTANCE CHARTS
   TRANSAXLE RANGE SWITCH OPERATION AND DIAGNOSIS
   STANDARD AND TIPTRONIC SHIFT QUADRANTS
   TYPICAL WIRE SCHEMATIC
   DIAGNOSTIC TROUBLE CODE DESCRIPTION
   TORQUE CONVERTER CLUTCH OPERATION
   PRESSURE TAP LOCATIONS AND IDENTIFICATION
   PRESSURE SPECIFICATIONS
   TRANSAXLE OIL COOLER INFORMATION
   OIL PASSAGE IDENTIFICATION
   CHECK FLUID LEVEL AND FLUID REQUIREMENTS
   OIL PAN “STAND-PIPE” DIFFERENCES
   OIL PAN AND OIL PAN GASKET DIFFERENCES
   OIL FILTER DIFFERENCES
   TRANSAXLE DISASSEMBLY
   COMPONENT REBUILD
   CONVERTER COVER ASSEMBLY
   TRANSAXLE CASE ASSEMBLY
   OIL PUMP ASSEMBLY
   K3 CLUTCH HOUSING ASSEMBLY
   K1 CLUTCH HOUSING ASSEMBLY
   K2 CLUTCH HOUSING ASSEMBLY
   REAR PLANETARY ASSEMBLY
   FRONT PLANETARY ASSEMBLY
   CENTER SUPPORT ASSEMBLY
   TRANSFER DRIVEN GEAR AND FINAL DRIVE ASSEMBLY
   VALVE BODY ASSEMBLY
   TRANSAXLE FINAL ASSEMBLY
   B2 CLUTCH CLEARANCE MEASUREMENT
   F1 ROLLER CLUTCH FREEWHEEL DIRECTION
   B1 CLUTCH CLEARANCE MEASUREMENT
   TRANSAXLE END-PLAY MEASUREMENT
   CONVERTER INSTALLED MEASUREMENT
   THRUST WASHER AND BEARING IDENTIFICATION
   TORQUE SPECIFICATIONS
   “UPDATED” TRANSAXLE CODE INFORMATION
Format: PDF
RAR password: auto-epc.org
AUDI, JETTA, PASSAT, 09G-09M Automatic Transmission.txt
Thanks given by: Admin
VW Volkswagen Passat Official Service Manual 1995-1997 Maximus 1 2,855 05-05-2013, 03:55 PM
Last Post: noppathon
