Skoda Fabia 2000 – 2006 Haynes Owners Workshop Manual
Skoda
[Image: %C5%A0koda-auto-car-%C5%A0koda-octavia-v...-skoda.jpg]
Skoda Fabia 2000 – 2006 Haynes Owners Service & Repair Manual covers models: Hatchback, Saloon & Estate, including vRS and special / limited editions.
Petrol Engines Covered:
   1.2 litre (1198cc) 3 cylinder
   1.4 litre (1397cc) 8 valve OHV
   1.4 litre (1390cc) 16 valve DOHC
DOES NOT cover 1.0 litre (997cc) or 2.0 litre (1984cc) petrol engines
Diesel Engines Covered:
   1.4 litre (1422cc) 3 cylinder TDi
   1.9 litre (1896cc) TDi & SDi
Introduction
The Skoda Fabia models covered by this manual were manufactured between March 2000 and December 2005.
Models included in this Manual are available with 1.2 litre 3-cylinder SOHC 6-valve, 1.2 litre 3- cylinder DOHC 12-valve, 1.4 litre 4-cylinder 8-valve, and 1.4 litre 4-cylinder 16-valve petrol engines. The diesel engines available are 1.4 litre 3-cylinder (6-valve) and 1.9 litre 4- cylinder (8-valve). 1.0 litre OHV and 2.0 litre 16-valve petrol engines are not covered in this Manual. 1.9 litre diesel engines are available in normally-aspirated and turbocharged versions. All petrol engines use multi-point fuel injection, and are fitted with a wide range of emission control systems. All the engines are of a well-proven design and, provided regular maintenance is carried out, are unlikely to give trouble.
Skoda Fabia models are available in 5-door Hatchback, 4-door Saloon and 5-door Estate bodystyles.
Fully-independent front suspension is fitted, with the components attached to a subframe assembly; the rear suspension is semiindependent, with a torsion beam and trailing arms.
A five-speed manual gearbox is fitted, with a four-speed automatic gearbox available as an option for 1.4 litre 16-valve petrol engine models. Note: At the time of writing, no information was available for the 6-speed gearbox (code 0A8) fitted to vRS models.
A wide range of standard and optional equipment is available within the model range to suit most tastes, including anti-lock braking, traction control and air conditioning.
For the home mechanic, Skoda Fabia models are straightforward vehicles to maintain, and most of the items requiring frequent attention are easily accessible.
Your Skoda Fabia Manual
The aim of this manual is to help you get the best value from your vehicle. It can do so in several ways. It can help you decide what work must be done (even should you choose to get it done by a garage). It will also provide information on routine maintenance and servicing, and give a logical course of action and diagnosis when random faults occur. However, it is hoped that you will use the manual by tackling the work yourself. On simpler jobs it may even be quicker than booking the car into a garage and going there twice, to leave and collect it. Perhaps most important, a lot of money can be saved by avoiding the costs a garage must charge to cover its labour and overheads.
The manual has drawings and descriptions to show the function of the various components so that their layout can be understood. Tasks are described and photographed in a clear step-by-step sequence.
Contents:
   Routine Maintenance
   Tune-Up Procedures
   Engine Repair
   Cooling And Heating
   Air-Conditioning
   Fuel And Exhaust
   Emissions Control
   Ignition, Brakes
   Suspension And Steering
   Electrical Systems
   Wiring Diagrams
File: PDF
RAR password: auto-epc.org
Skoda Fabia 2000-2006 Haynes Owners Workshop Manual.txt
Thanks given by: Admin , enzod , rileeeee
Skoda Skoda Octavia 1998-2004 Haynes Owners Workshop Manual tiger1984 0 2,239 11-14-2016, 04:41 AM
Last Post: tiger1984
