Fiat Multiecuscan v3.1 FULL Registered
Fiat
Diagnostic Software
Fiat Multiecuscan is a vehicle diagnostic software with advanced functions. It allows you to perform various diagnostics tasks on the supported vehicles/modules. In order to use the software you need an interface. The following interfaces are currently supported by the software:
KL (also known as VagCom 409), ELM327 (1.3 or newer), OBDKey 1.40, OBDLink, ELM Scan 5, CANtieCAR.
- O.S.: Windows 7, Windows 8, Windows 8.1, Windows 10
- CPU: Pentium/Athlon 2 GHz or higher
- RAM: 512 MB of system memory
- Hard Drive: 100 MB of available space
- Optical Drive: CD-ROM
Fiat Multiecuscan v3.1 FULL Registered ISO.txt
HDD_Change_Serial_Number.zip
Install Instructions.txt
multi.txt
Thanks given by: muftah76 , KrisIveco , ekg00
