AlfaOBD for PC v1.9.4 + ACTIVATION
Alfa
[Image: 2hgwnjr.png]
[Image: s5bww3.png]
[Image: 1zo926g.png]
[Image: 28b88k6.jpg]
[Image: 9st5ar.jpg]
AlfaOBD is a software for Fiat / Alfa / Lancia diagnostics. Although it is primarily targeted for car owners, it provides many of the features of professional scanners.
AlfaOBD natively supports Electronic control units installed in Fiat group cars, including the newer cars produced in cooperation with Chrysler/Dodge. Native support differs AlfaOBD from many other diagnostic applications providing only limited OBD II generic support.
AlfaOBD features include:
   monitoring various dynamic parameters of body, dash, code, engine, gearbox, ABS, climate control, etc. and graphical presentation as adjustable plots
   reading of static data (ECU id, system status, fault codes with probable causes and environment information where applicable)
   clearing fault codes, monitoring the system for appearance of new faults
   active diagnostics and configuration procedures for various equipment controlled by engine, gearbox, body computer, climate control, ABS, airbag, code control and other ECUs. Service light reset, engine oil change, DPF regeneration and many more.
   electronic key and RF remote control programming
For the full list of supported ECUs see Supported Units.  See Supported Cars for the full list of supported cars.
The software requires a compatible OBD interface.
Arrow To obtain Activation code, please post your License request code here in topic.
AlfaOBD for PC v1.9.4.txt
Downloaded: 11 times
Alfa AlfaOBD 2.4.4.0 for PC + AlfaOBD 2.3.3 for Android motorstate 2 5,018 05-03-2023, 12:21 AM
Fiat AlfaOBD 1.9.2.0 for PC & Windows Mobile + AlfaOBD for Android 2.0.1 Thunder 0 3,490 01-27-2017, 02:28 AM
