VCDS lite VAG-COM 409 + CRACK+ USB Drive
ELSAWin
(Registered & Activated)
VCDS-Lite is a Windows-based Diagnostic tool for VW/Audi/Seat/Skoda for non-dongle interfaces. With VCDS-Lite you can do an automatic scan of all controllers for Fault Codes. Also, you can select an individual Control Module such as Engine, ABS or Airbag.
Works with simple K-Line/KL line/KKL-Line/VAG-COM 311/VAG-COM 409 interfaces (ISO 9141-2 protocol)
VCDS lite VAG-COM 409 + CRACK+ USB Drive.txt
Downloaded: 58 times
instructions.doc.txt
Downloaded: 34 times
ELSAWin VCDS lite v18.2.1 Spanish +Italian + Portughese FULL Admin 0 3,651 09-19-2018, 07:05 AM
