  • 2 Vote(s) - 1.5 Average
Vivid WorkshopData ATI v10.2 Release 2010-Q2 Final (NEVER EXPIRE)
[Image: vivid-1.jpg]
Vivid WorkshopData ATI v10.2 Release 2010 Q2 Final
WorkshopData ATI is our new information product available on CD and DVD. It is based on Vivid’s technical database, the most extensive repertory of car data in Europe. Vivid WorkshopData provides technical information on cars and light commercial vehicles, e.g. essential maintenance and repair information, adjustment data, technical drawings and engine management data.
Extra modules are: Wiring diagrams (comfort electronics) and Repair Times. Its content is second to none.
Year: 2010
Release Version: Vivid Workshop: 2010-Q2
Compatibility with XP / Vista / 7: yes
Language: Multilanguage
At this moment Vivid WorkshopData offers:
- Almost 6,500 engine types
- Over 45,000 technical drawings
- Over 5,600 engine management systems
- Thousands of wiring diagrams
- Millions of specified repair times
- And much more
* Identification Data
* Lubricants and Fluids
* Adjustment Data
* Environmental Data
* Maintenance
* Engine and Timing Belt
* Removal
* Repair Manuals
* Air conditioning and Climate
* Control (mechanical)
* Automatic Transmission
* ABS (mechanical)
* Key Programming
* Technical Drawings
* Engine Management
* Wiring Diagrams A/C
* Systems
* Repair Times
* Wiring Diagrams Comfort
* Electronics
* Workshop Organiser
* Electronic Smart Assistant
What's new …
Electronics Smart Assistant
Automotive electronic technology is developing rapidly. To diagnose faults accurately, the automotive technician now needs detailed information on complex electronic processors (ECU’s) and their associated components. A single diagram displayed on a PC is no longer enough.
Designed specifically for the diagnosis and repair of modern vehicle electronic systems, the Electronics Smart Assistant will change the way the automotive
aftermarket views car electronics and diagnostics. The Smart Assistant is easy to use.
You can either enter EOBD codes or go straight to an electronic component. Clear, step-by-step instructions then lead you to an accurate diagnosis.
Our database contains thousands of standard P-codes, manufacturers’ fault codes, and detailed wiring diagrams, making the diagnostic process quick and easy.
The Electronics Smart Assistant is available either integrated within the application or as a stand-alone module.
NO PASSWORD - Enjoy All Wink
Vivid WorkshopData ATI v10.2 Release 2010-Q2.zip
Downloaded: 13 times
Already have this, and now im getting a date warning ,so it is gonna become a bit of a pain changing the date every time i want to use it, until the 10.5 version surfaces
Use the above tool "RunAsDate", create a new shortcut to your Desktop and your program will never expire Big Grin
Hello
I installed the program I put the crack and RunAsDate, now the program runs but I did not bring results.
The license says that I have zero days yet.
Edit:
Thanks i fix the problem . Give5
i run it. and become attention it's database is old. you have to update.then it's closed. what can i do?
just run "RunAsDate" and crack check read only .
(09-09-2011, 02:43 AM)gmavro Wrote: Hello
Edit:
hi . i have the same problem also !
hpw can fix the problem ?
thank you so much !
Edit:
thank you so much !
when copy the crack in the folder , then right click in dll and mark read only.
If you run before the program uninstall first and install again.
no problem to install and working good! Thank You.
You're welcome guys. Please click to the "Thanks" button instead of write Wink
ZZ.Blank Vivid WorkshopData ATI v12.1 (2012) Creeping_Back 0 13,904 12-22-2012, 05:12 AM
Last Post: Creeping_Back
