JPRO Commercial Fleet Diagnostics 2016 v1.0 [01.2016]
Noregon JPRO
Noregon JPRO Commercial Vehicle Diagnostics
Version: v1.0
Date of update: 01/2016
Coverage Updates (Available as a part of JPRO Fleets 2016 v1.0):
Quote:Auxiliary Components
Freightliner
M2 Bulkhead Module
Bendix Wingman Systems
WHAT'S NEW
Quote:- Support for the new JPRO with ASIST module which provides the ability to
  upload vehicle connection data to the ASIST platform, developed by Decisiv for
  Volvo and Mack Trucks
  NOTE: Installing the ASIST module will require personnel with ASIST Admin level
  access to provide ASIST Username and Password.
  NOTE: The ASIST module require either a heavy-duty or medium-duty module to be able
  to connect to vehicles.
- JPRO Heavy-Duty Module
   - Data Monitor update to show Power Diagram to aid in the diagnosis
     of electrical problems
   - Support for Paccar 2010 and newer CAN Body Controllers
   - Clear faults support for Paccar engine controllers
   - Support for more proprietary sensor data on Detroit engines
- JPRO Heavy-Duty Command Module - Detroit
   - Additional Bi-Directional support for Detroit engines:
      - Cylinder Cut-Off now available for 2000-2014
      - DPF Service Regen now available for 2007-2014
For Activation ask it in this topic :
Arrow   JPRO (2015 - 2016) Activations Keys
JPRO Commercial Fleet Diagnostics 2016 v1.0 [01.2016].txt
Thanks given by: mark2015
Noregon JPRO JPRO Commercial Fleet Diagnostics 2017 v1.0 [01.2017] + ACTIVATION Admin 3 8,406 09-16-2021, 04:12 AM
Noregon JPRO JPRO Commercial Fleet Diagnostics v3.0 [12.2015] Admin 1 4,839 01-28-2018, 02:20 PM
Last Post: mcartier
Noregon JPRO JPRO Commercial Fleet Diagnostics 2016 v2.3 [05.2016] + ACTIVATION Admin 0 4,641 11-19-2016, 02:15 AM
Noregon JPRO JPRO Commercial Fleet Diagnostics 2016 v2.0 [02.2016] + KEYGEN Admin 0 8,688 10-26-2016, 05:06 AM
Noregon JPRO JPRO Commercial Fleet Diagnostics v2.1 [08.2015] Admin 0 4,548 09-02-2015, 01:28 AM
Noregon JPRO JPRO Commercial Fleet Diagnostics v1 [01.2015] Admin 0 5,487 04-04-2015, 06:22 AM
