JPRO Commercial Fleet Diagnostics 2017 v1.0 [01.2017] + ACTIVATION
Noregon JPRO
JPRO Commercial Fleet Diagnostics 2017 v1.0 [01.2017] + KEYGEN
Noregon JPRO Commercial Vehicle Diagnostics
[Image: 1.png]
[Image: 2.png]
[Image: 3.png]
[Image: 4.png]
[Image: 5.png]
[Image: a01.png]
[Image: a02.png]
Version: v1.0
Year: 2017
Date of update: 01/2017
Coverage Updates (Available as a part of JPRO Fleets 2017 v1.0):
Quote:Auxiliary Components
Freightliner
M2 Bulkhead Module
Bendix Wingman Systems
WHAT'S NEW
Quote:- Support for the new JPRO with ASIST module which provides the ability to
  upload vehicle connection data to the ASIST platform, developed by Decisiv for
  Volvo and Mack Trucks
  NOTE: Installing the ASIST module will require personnel with ASIST Admin level
  access to provide ASIST Username and Password.
  NOTE: The ASIST module require either a heavy-duty or medium-duty module to be able
  to connect to vehicles.
- JPRO Heavy-Duty Module
   - Data Monitor update to show Power Diagram to aid in the diagnosis
     of electrical problems
   - Support for Paccar 2010 and newer CAN Body Controllers
   - Clear faults support for Paccar engine controllers
   - Support for more proprietary sensor data on Detroit engines
- JPRO Heavy-Duty Command Module - Detroit
   - Additional Bi-Directional support for Detroit engines:
      - Cylinder Cut-Off now available for 2000-2014
      - DPF Service Regen now available for 2007-2014
Install guide.pdf
File Type: .pdf
Downloaded: 33 times
JPRO Commercial Fleet Diagnostics v1.0 [01.2017] ISO.txt
Downloaded: 29 times
Thanks given by: craneauto
Dear you can you send me license for this
Å”ËjSQ†ÿ”ê *EžYÁ¶''÷â 'iŽ4šzƒNjrÔ`n˜X[ŸÁGð "8qèã¨ßÁßÚ-Ô»P(žÍ:Yûßký{ÝNRKJ+PNE-+«RAË¡eTE+i]†åª€²ŠŠ´È{d”)é Œ‰úi¢]cÁ³¥–"KǍ4ÞÆò9èÆX›—ÓŒ+ˆY\Å»§r6PWûœo£·Á =ä x‚¿Ó&|ç¥pÛóv:î}ùX^DßÔ"ÜÖò¬"iªp(yYÎ1ÙåÙJao9Þ“qÅœôÛguÇ9¯J—]ÂyV«çIî7¶ö%‚#›ü--pâþ°BÎ3º¯R§_àWZ—ÑcY…jè¨ï.qšÖëZߟu9¹„õkiÂeYoyD&ëd²AujðÚcÐÀ«
ߦ¡ÓG ]zØaÿRÖ½r—ŽNÀûÜ1ñU:‹·e·¬GàͰ¯jÍ×Ü~w~â¹9__|ÿõSùVôæõ‡Ôç²ÃnŸÊeáŠaícÝc&˜#!ž ˆõ#äÝ’Ý;ò}0[×y8nË&ð…Gòx»ž–8û~·¥øTáµ./Ñ£†Gºda_K†€M“|Ê¾36•·ÔõJá¬mÍ¿Mb~Mž*Nøeü:·ßñªlzV={úÔæÖ:Q µ9-*ôX,›ßœìV›—
]B+âSUƳZ¶ːӉlá/=ù÷ŸÊ!6W~°}§ã^öØáasÞö•û³ÿ5#ü½ûç
Please send activation for JPRO 2017.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(09-15-2021, 01:19 AM)doctech101 Wrote: Please send activation for JPRO 2017.
doctech101_2021-09-15_.rar
Noregon JPRO JPRO Commercial Fleet Diagnostics v3.0 [12.2015] Admin 1 4,832 01-28-2018, 02:20 PM
Last Post: mcartier
Noregon JPRO JPRO Commercial Fleet Diagnostics 2016 v2.3 [05.2016] + ACTIVATION Admin 0 4,632 11-19-2016, 02:15 AM
Noregon JPRO JPRO Commercial Fleet Diagnostics 2016 v2.0 [02.2016] + KEYGEN Admin 0 8,681 10-26-2016, 05:06 AM
Noregon JPRO JPRO Commercial Fleet Diagnostics 2016 v1.0 [01.2016] Admin 0 3,308 02-15-2016, 04:27 AM
Noregon JPRO JPRO Commercial Fleet Diagnostics v2.1 [08.2015] Admin 0 4,543 09-02-2015, 01:28 AM
Noregon JPRO JPRO Commercial Fleet Diagnostics v1 [01.2015] Admin 0 5,483 04-04-2015, 06:22 AM
