Xentry OpenShell XDOS Patcher 2.0
#11
(04-24-2021, 09:42 AM)verebandras25 Wrote: HWID:
BE1AF-20869-3AD70-DB7F2-A1270-4C598-12AF8-A1ABE thx
Key: umoz79502Z2hmhgjAbXJn7UL3wuFdI3IvIkBh+AMqz0wdzaF+p95jaf=WEo3oTJxsqfd8GtGP5lpACV=TML=yA9G81OJsmaP17Vm6xC9lELHXA8dvRNQkk+3C11D
HWID:
1583F-2080A-A6D70-DB7F2-24670-4C516-347E3-3FE20
id hardweru: A170F-208EA-4FD70-D3A3A-BCAF0-4C598-12ED0-BFB16 thanks
(02-04-2016, 04:54 AM)Admin Wrote: Xentry OpenShell XDOS Patcher 2.0
Disable UAC settings Before run Patcher:
Disable UAC settings to "Never notify" -> Restart system -> Apply Patch or Undo -> Then, you could return UAC settings back.
It`s better to DISABLE idiotic Windows Defender too.
Patcher automatically detect system OS Type 64-bit or 86-bit .
How to use XENTRY OPENSHELL Patcher:
Quote:1- Close Starkey Center
2- Run xentry Patcher , Patcher will run automatically as  Administrator
3- Click on Patch Starkeycenter
4- Click on Patch XENTRY Activations
5- Click on FIX XENTRY Activations
6- Close Patcher
7- Run Starkey Center and Use Old Keygen for Xentry and DAS And WIS
Whats's New!
Xentry:
Add Patch Missing Pictures fix 2015
DAS Standalone:
Add Fix No DAS Key & Timeout fix Required
Add DAS Standalone 7.7.0 & Shortcut to Desktop
Add Switch DAS To SD Connect C3
Add Switch DAS To SD Connect C4
SD Connect Switcher:
Add Switch ToolKit To SD Connect C3
Add Switch ToolKit To SD Connect C4
Note :
  When you activate program the first time,
  must provide the Internet connection on device to be activated successfully,
  after activate program you can use it without Internet
How Install WIS Standalone:
You must provide (2) partition on Disc
C:\ & D:\
Change Drive Letter for partition D:\ To E:\ Then Click patch WIS STANDALONE
Arrow Post your Hardware ID to get your License KEY !!!
Direct Download | Single Extraction | Real Screen Shots
My hardware is
HWID:
BBBEF-2086B-7E8A7-36E88-28900-4C5C1-8C7AC-D2EA4
thanks
Thanks given by: Ve1ya
#15
BD57F-208A0-F4E26-CFF55-282A0-4C5C5-7F2F6-53509
Thank you !
Here is my HWID
EE3DF-208F9-1ED70-DF250-A53E0-4C583-07389-CB0D5
thanks
Mercedes Xentry OpenShell 09.2025 HHT (+C3) WIS EPC Vediamo Monaco (Acronis L+UEFI) motorstate 5 7,890 04-12-2023, 07:50 PM
Mercedes Xentry OpenShell 25.3.4 + Daimler S_DTPID 24.4.3 motorstate 8 10,761 11-28-2022, 05:18 PM
Mercedes Mercedes DAS XENTRY OpenShell XDOS 31.8.2.0 [06.2022] Admin 0 2,888 06-01-2022, 04:58 AM
Mercedes Mercedes DAS XENTRY OpenShell XDOS 30.8.2.1 [12.2021] Admin 0 3,529 11-29-2021, 06:51 AM
Mercedes Mercedes DAS XENTRY OpenShell XDOS 29.8.2.2 [09.2021] Admin 0 4,789 09-07-2021, 06:00 AM
Mercedes Mercedes DAS XENTRY OpenShell XDOS 28.9.3.2 [03.2021] Admin 0 4,596 03-18-2021, 11:41 AM
Mercedes Mercedes DAS XENTRY OpenShell XDOS 28.9.2.3 [12.2020] Admin 0 4,227 02-28-2021, 05:33 AM
Mercedes Mercedes DAS XENTRY OpenShell XDOS 27.15.2.3 [09.2020] Admin 0 4,080 08-06-2020, 05:38 AM
Mercedes Mercedes DAS XENTRY OpenShell XDOS 26.9.3.2 [03.2020] Admin 0 5,419 03-24-2020, 07:03 AM
Mercedes Mercedes DAS XENTRY OpenShell XDOS 19.12.6 [12.2019] Admin 0 3,413 11-27-2019, 05:55 AM
