  • 2 Vote(s) - 1.5 Average
Vivid WorkshopData ATI v10.2 Release 2010-Q2 Final (NEVER EXPIRE)
#41
Hey @basco, you must read the instructions and use the crack only. There is no site code for this program.
(09-07-2011, 02:44 PM)TestPoint Wrote: Use the above tool "RunAsDate", create a new shortcut to your Desktop and your program will never expire Big Grin
iHi,
Have downloaded and installed...but I can't find the 'Crack folder'
Regards
iHi,
Regards
Check post #1 for more informations Wink
Great! I just installed and it works ...
Hi ,thanx a lot.I have installed and it work !!
Give5Idea Se agradese este aporte gracias 58Dodgy
_____________________ INSTRUCTIONS _____________________
cant do this. i have spent the last 4 hours trying it.. done all the above 3 or four times over the only thing i cant find is
C:\ProgrammData\WorkshopData\48\...... keep getting 0 days the program opens but you cant do anything don't all the run date tried both dates in the above topic no luck. changes the crack and made it read only i must be doing something wrong. i am using window 7
1. Mount image with Daemon Tools and install
2. After installation, copy & replace CRP32DLL.dll from the CRACK folder to installation folder (C:\Program Files\Vivid WorkshopData ATI\)
3. Make sure the file CRP32DLL.dll is READ ONLY.
Post #1 has been updated with new links. Please check it Wink
(01-25-2012, 09:49 PM)TestPoint Wrote: Post #1 has been updated with new links. Please check it Wink
thanks for your help. i don't understand what new links, do you mean down load the program again.
i now have read all post 6 time remove and redone it... run date program seem to be working. if you go forwards its say program out of date you go backwards it say 0 days left. i take it when you make dii read only you do that in dii property's i can not see what i doing wrong. i did notice that it dose not ask about internet. it just open say 0 day left. then you open the program but you cant open any folders... i am not usually bad with this sort of thing but i seem to be making a mess of this .
so i put the run date pro and made short cut date set to 1 1 2011. put the dii crack in made it read only.
am i missing anything out
Change the date to 01.01.2010 not 2011 Smile
ZZ.Blank Vivid WorkshopData ATI v12.1 (2012) Creeping_Back 0 13,745 12-22-2012, 05:12 AM
Last Post: Creeping_Back
3 Guest(s)
