TecDoc CATALOG 04/2011 Multilanguage
#31
I'm asking you again: Do you read the instructins or not ?
i did all 3 steps.
1-i used TecDOC 01.2010 patch.exe
2-i Copied & Replaced "stdocxx.tmp" and "tof.dsn" to "C:\TECDOC_CD\1_2011\pb\", (C= my installation drive)
3-it created in only C:\TECDOC_CD\4_2011 that files "SftTree_IX86_U_50.ocx" and "SftTree_IX86_U_65.ocx
i copied "SftTree_IX86_U_50.ocx" and "SftTree_IX86_U_65.ocx in c:\windows\system32\
but it still same. Testpoint
there are anything that i didn't
Yes. Now TecDOC must be working fine. What is your problem ?
tecdoc could not connect database.
i abandon. thanks for everything.
TecDOC is working fine mate. The problems come from your installation or your operating system.
Uninstall, clean your registry and tryn again, else do a fresh installation on a new operating system.
See the screenshots and read some above posts...
I had a similar problem
Just open tof.dsn in a text editor
then make sure, the database is connected to the correct database
for instance
After installation, my file read:
[ODBC]
DRIVER=Transbase ODBC TECDOC CD 3_2011
DATABASE=TECDOC_CD_3_2011
But it was suppose to read:
[ODBC]
DRIVER=Transbase ODBC TECDOC CD 4_2011
DATABASE=TECDOC_CD_4_2011
After this little change, all was working fine
I hope it will work for you as well.
TronCar
hi, i have installed tecdoc 04 2011 as fullinstall and started the patch and copied all the files into \\pb folder
i can start tecdoc but everything is grey. i use win7, 32-bit and have only the instructions text with kyrilliansymbols and can't understand the instructionsSad
can anyone help me?
Right click to TecDOC shortcut and change the COMPATIBILITY to Windows XP SP2 or SP3 Smile
its working now, i can see all the parts, but there are no prices available,
thanks a lot for the first tip
Smile
links are dead...can smbd re-up?
  TecDoc CATALOG (04.2012) Multilanguage TestPoint 24 42,678 01-16-2013, 05:05 AM
Last Post: burnout
  TecDoc CATALOG 03/2011 Multilanguage TestPoint 3 10,107 09-15-2011, 06:09 PM
Last Post: COMBRA
  TecDoc CATALOG 02/2011 Multilanguage + FINAL CRACK TestPoint 0 6,444 09-02-2011, 04:50 PM
