Xentry OpenShell 09.2025 HHT (+C3) WIS EPC Vediamo Monaco (Acronis L+UEFI)
Xenty Cars OpenShell 09.2025 (terabox) + All OpenShell 09.2023 (torrent) HHT (+C3) DAS WIS EPC STARFINDER VEDIAMO MONACO (Acronis L+UEFI)
Computer requirements:
  • HDD or SDD 480 Gb
  • RAM 4 Gb
  • Processor with support for virtualization technology (enable virtualization in BIOS).
VHD image with Windows 10 LTSC x64 Rus (by default) + English.
This version is a revision and modification of the 03.2023 image, it is fully configured for offline, all offline patches are applied and additional ones are activated. functions for DAS. A patch for Xentry Offline login has been applied. XUS 6.8.0.0 configured and activated! The data map in WIS and EPC has been configured, shortcuts for direct launch are also made, and the transition from Xentry and DAS to WIS is activated (WIS must already be launched before starting Xentry or DAS).
Why VHD and not Acronis? - VHD is a more universal format, you can immediately boot from it without expanding the image by making a couple of clicks in the Easy BCD program. Can be connected to virtual machines. You can deploy it as an acronym or other programs to disk (it is recommended to use VHD2DISK). In two clicks it is mounted in the system and you can take any information from there. Added Strelec WINPE and Rufus to create a bootable USB flash drive for image recovery.
Programs in the image:
  • Xentry OpenShell 06.2023
  • DAS SCN offline coding (SDFlash 07.2018)
  • Xentry OpenShell 09.2014 (virtual machine for SD Connect С3 and direct connections to ECU from DAS to HHTwin)
  • Xentry Update Service 6.9.0.0
  • Vediamo 05.01.01 + configured for С6, Xentry VCI, VCX SE
  • DTS Monaco v8.14.016 + projects 2022 (8.16.015 with my activation) + configure for С6, Xentry VCI, VCX SE
  • EPC 11.2018
  • WIS 10.2020
  • WIS standalone 2021/07
  • StarFinder 2016 (with wiring diagrams) + 2020 (without)
  • COMANDDownloadManager login: DLM password: DLM
  • HTTwin на Hyper-V password: 111
  • FDOK
  • MBSeedKey + DLLs 2020
  • Seed Calculator + DLLs 2020
  • DisassembyAssistant
  • Regio ECU 09.2014
  • VGSNAG2 Manager v1.6
  • SDmedia
  • Vediamo and DTS Monaco manuals
[Image: 78ad0af9046136bcef46cfc240fbecc0.jpg]
[Image: 8c0a012facb7e902de5b4470dae7c673.jpg]
Xentry Openshell Acronis.txt
Added Xentry OpenShell 12.2021 HHT (+C3) WIS EPC Starfinder Vediamo Monaco (Acronis L+UEFI)
Added new image 06.2022
Thanks given by: oicsi
Added new image Xentry OpenShell 09.2022 HHT (+C3) WIS EPC Starfinder Vediamo Monaco (Acronis L+UEFI)
Added new image Xentry OpenShell 12.2022 HHT (+C3) WIS EPC Starfinder Vediamo Monaco (Acronis L+UEFI)
Added Xentry OpenShell 03.2023 HHT (+C3) DAS WIS EPC STARFINDER VEDIAMO MONACO (Acronis L+UEFI)
Mercedes Xentry OpenShell XDOS Patcher 2.0 Admin 15 25,414 03-17-2025, 06:45 AM
Last Post: pktech
Mercedes Xentry Passthru 06.2023 XUS HHT DAS WIS EPC STARFINDER VEDIAMO MONACO (Acronis) motorstate 4 8,326 03-04-2023, 05:11 AM
Mercedes Xentry OpenShell 25.3.4 + Daimler S_DTPID 24.4.3 motorstate 8 10,771 11-28-2022, 05:18 PM
Mercedes Mercedes DAS XENTRY OpenShell XDOS 31.8.2.0 [06.2022] Admin 0 2,893 06-01-2022, 04:58 AM
Mercedes Mercedes DAS XENTRY OpenShell XDOS 30.8.2.1 [12.2021] Admin 0 3,532 11-29-2021, 06:51 AM
Mercedes Mercedes DAS XENTRY OpenShell XDOS 29.8.2.2 [09.2021] Admin 0 4,794 09-07-2021, 06:00 AM
Mercedes Mercedes DAS XENTRY OpenShell XDOS 28.9.3.2 [03.2021] Admin 0 4,597 03-18-2021, 11:41 AM
Mercedes Mercedes DAS XENTRY OpenShell XDOS 28.9.2.3 [12.2020] Admin 0 4,228 02-28-2021, 05:33 AM
Mercedes Mercedes DAS XENTRY OpenShell XDOS 27.15.2.3 [09.2020] Admin 0 4,081 08-06-2020, 05:38 AM
Mercedes Mercedes DAS XENTRY OpenShell XDOS 26.9.3.2 [03.2020] Admin 0 5,421 03-24-2020, 07:03 AM
