JETI ForkLift (ET-SH-Judit JAG) - Activations Keys
#21
(03-30-2012, 06:15 AM)Alcoholahmed Wrote:
(03-29-2012, 08:40 PM)nicky1 Wrote:
(03-29-2012, 04:01 PM)Alcoholahmed Wrote:
(03-29-2012, 07:35 AM)nicky1 Wrote: I have installed Security Client for Jeti Full.
Please give authorisation code for order code: "0002-00gq-cab6-2k86-a6a0"
so thanks!
Kind regards
iuv3-5n25-ihih-2000-100k-4f00-00fu-l250-00
Got it to install, but License of ET shows ! sign in overview and is out of Date per 31.1.2012 - doesnt work.
Can you help ?
kind regards
you need to set the date back to 2009 or 2010 m8..
hi
for jeti 4.18 or4.19 is that rigth
but for steti is the right date 2004 or 2005
regards
[Image: uzara.png]
(03-30-2012, 05:22 AM)uzara Wrote: Hi
both is in the forum
steinbock and steinbock from jungheinrich
this software use a old security client or a spez.security client
you must date back for this software !!!!
pls help on jeti code 1002-00sn-kmob-o6c6-06a0 ?
try this l3u0-kcm1-j1gh-i000-100k-4f00-00fu-l250-00
what steinbock you have ?? from jungheinrich or orig.
regards
looks exactly like jungheinrich cd just with different data content
Thanks!
so thanks!
Kind regards
Can you help ?
kind regards
hi
regards
Thanks, just trying this! Also reinstalled Licence gave me new code - sorry to bother you again...
again Jungheinrich full DVD, code now : 0002-0081-pu8m-urvg-9500
Thanks in advance, especial for your patience with me :-)
Kind regards!
regards
Thanks!
Can you help ?
kind regards
hi
regards
Kind regards!
your new code: naii-mivu-7ca1-0000-100k-4f00-00fu-l250-00
befor we make it again and again tell me :
what dvd version and what client you use?
and what date to install?
the clients not up compatible
regards
[Image: uzara.png]
regards
You have a good point there, understand, thanks again for your efforts and patience!! :-)
Im fighting with two DVDs from autoepc.com.ua:
One is Jungheinrich JETI DVD Version 4.22 with SecurityClient from Client folder on DVD; actual date and 2010 showed same Result - Licence was accepted, Install out of Licence Menue was working and finished fine, but Application doesnt run.
http://autoepc.com.ua/Jungheinrich-Parts...p-925.html
Other is Steinbock STETI CD 1 Version 3.6 tried 2004 without much chance, SecurityClient from Client folder on CD, Licence was accepted, Software install from Licence Window gives error.
http://autoepc.com.ua/Steinbock-STETI-Pa...-1054.html
Also got the Two Toyota Forklift Sparepart CDs which are Working fine and easy ;-)
own you much already!
Kind Regards
regards
Kind Regards
Have you steti and Jeti 4.22 install or trying to install on the same PC ?
if yes than you must clean the registry from all steti and jeti elements
because steti and jeti dont work same pc (many conflcts )
[Image: uzara.png]
(03-31-2012, 05:10 AM)uzara Wrote: Hi
Thats right, after trying to install steti everything changed to the bad!
So next time ill use steti on a different PC and clean reg now.
Please authorization code
Order code
0002-00ce-oimb-6s5t-sk90
Thanks Give5
(04-03-2012, 04:13 AM)janes75 Wrote: Please authorization code
Order code
Thanks Give5
your code is : 0v2t-d62f-977d-2000-100k-4f00-00fu-l250-00
regards
[Image: uzara.png]
Dear Moderator
Kindly help me to provide Athorization code,. and my order code is 0002-00cd-31k1-mb5q-did1 , Thank's
Kind Regard's
(04-07-2012, 04:04 AM)kazai Wrote: Dear Moderator
Kind Regard's
Your code is: nip9-tosa-hejc-b000-100k-4f00-00fu-l250-00
regards
[Image: uzara.png]
Keys Liebherr Lidos & Lindos EPC - Activations Keys alcoholahmed 535 471,622 02-04-2025, 03:40 PM
Last Post: gabbiiiyyyy
Mercedes Mercedes DAS Xentry Devoloper - Activations Keys Admin 225 238,524 07-02-2024, 04:00 AM
Last Post: Jiinn
Keys Tolerance Data - Activations Keys Admin 63 81,419 12-11-2023, 03:08 AM
Last Post: kreten1234
Perkins PERKINS (EST, SPI2 , EDI 1300) + FG Wilson (compass, EST) - Activations Keys alcoholahmed 346 336,389 12-08-2017, 05:12 AM
CAT CAT ET, SIS and STW - Activations Keys alcoholahmed 745 986,976 12-03-2017, 06:53 AM
Actia-logo ACTIA Multi-DIAG ALL Versions - Activations Keys alcoholahmed 401 731,536 10-24-2017, 04:15 AM
Cummins Cummins Insite - Activations Keys alcoholahmed 316 319,649 06-10-2017, 04:31 AM
Cummins CUMMINS Inpower Pro v.7x - Activations Keys Admin 6 11,783 06-09-2017, 09:24 PM
Last Post: maryo65
Keys Jungheinrich Judit - Licence Keys Bycom2003 32 41,858 12-04-2016, 01:54 AM
Last Post: chumberri
Keys CLARK ForkLift PartPro - Activations Keys alcoholahmed 141 124,897 09-21-2016, 06:57 AM
