JPRO Commercial Fleet Diagnostics 2017 v1.0 [01.2017] + ACTIVATION
Noregon JPRO
Noregon JPRO Commercial Vehicle Diagnostics
[Image: 1.png]
[Image: 2.png]
[Image: 3.png]
[Image: 4.png]
[Image: 5.png]
[Image: a01.png]
[Image: a02.png]
Version: v1.0
Year: 2017
Date of update: 01/2017
Coverage Updates (Available as a part of JPRO Fleets 2017 v1.0):
Quote:Auxiliary Components
Freightliner
M2 Bulkhead Module
Bendix Wingman Systems
WHAT'S NEW
Quote:- Support for the new JPRO with ASIST module which provides the ability to
  upload vehicle connection data to the ASIST platform, developed by Decisiv for
  Volvo and Mack Trucks
  NOTE: Installing the ASIST module will require personnel with ASIST Admin level
  access to provide ASIST Username and Password.
  NOTE: The ASIST module require either a heavy-duty or medium-duty module to be able
  to connect to vehicles.
- JPRO Heavy-Duty Module
   - Data Monitor update to show Power Diagram to aid in the diagnosis
     of electrical problems
   - Support for Paccar 2010 and newer CAN Body Controllers
   - Clear faults support for Paccar engine controllers
   - Support for more proprietary sensor data on Detroit engines
- JPRO Heavy-Duty Command Module - Detroit
   - Additional Bi-Directional support for Detroit engines:
      - Cylinder Cut-Off now available for 2000-2014
      - DPF Service Regen now available for 2007-2014
JPRO Commercial Fleet Diagnostics v1.0 [01.2017] ISO.txt
Downloaded: 23 times
Install guide.pdf
File Type: .pdf
Downloaded: 12 times
Thanks given by: osama123
Noregon JPRO Noregon JPRO Commercial Fleet Diagnostics 2016 v2.3 + Activator Thunder 0 2,920 02-23-2017, 03:46 AM
Noregon JPRO Noregon JPRO Commercial Fleet Diagnostics 2016 v2.2 + Activator Thunder 0 4,228 11-30-2016, 06:42 AM
ZZ.Blank JPRO Commercial Fleet Diagnostics 2016 v2.3 [05.2016] - PREACTIVATED tiger1984 0 2,638 11-18-2016, 06:36 AM
Last Post: tiger1984
ZZ.Blank Noregon JPRO Commercial Fleet Diagnostics 2016.2 + Activator Thunder 0 2,962 07-25-2016, 08:06 AM
Noregon JPRO JPRO Commercial Fleet Diagnostics [01.2014] Admin 0 5,270 01-13-2015, 05:58 AM
