JPRO Commercial Fleet Diagnostics 2016 v2.3 [05.2016] - PREACTIVATED
Version: 2.3
Date of pdate: 05/2016
What’s New
Quote:JPRO Professional Diagnostic Software for AU
Includes all features provided by the following modules:
   JPRO Heavy-Duty Module
   JPRO Heavy-Duty Command Module – Cummins
   JPRO Heavy-Duty Command Module – Detroit
   JPRO Heavy-Duty Command Module – International
   JPRO Medium-Duty Command Module – Isuzu
   JPRO Medium-Duty Command Module – Sprinter
NOTE: Mack and Volvo, Ford, GM and JPRO Next Step are not supported in Australia.
JPRO Professional Diagnostic Software with Next Step
   ● Now includes:
● Bi-Directional support for International engines:
   International Cylinder Cut Out
       EPA 07 Maxxforce 7, DT, 9, 10, 11, and 13
       EPA 10 Maxxforce DT, 9, 10, 11, and 13
       EPA 13 Maxxforce DT, 9, 10, 11, 13 and N series
   International DPF Regen
       EPA 10 Maxxforce 7, DT, 9, 10, 11, and 13
       EPA 13 Maxxforce 7, DT, 9, and 10
Supports the following vehicle models from 2008-2016 with either the 5.2L (4HK1) or 3.0L (4JJ1) engine in both North America and Australia:
   N-Series faults and data (engine and transmission only)
   F-Series faults (engine only)
   Supports the medium duty GMLAN messages.
   Gives users the ability to read and clear faults and read freeze frames.
   Displays emission test results in North America.
JPRO Heavy-Duty Command Module – Mack and Volvo
   Now supports NEXIQ USB-Link 2 adapter connections
JPRO with ASIST
   Ability to ‘Select New’ or ‘Update’ existing case upon ASIST submission
   Additional data is now sent to ASIST system including 30+ data items as well as the ECU Software Version
RAR password: auto-epc.org
JPRO 2016 v2.3 PREACTIVATED.txt
Downloaded: 20 times
Thanks given by: Admin
Noregon JPRO JPRO Commercial Fleet Diagnostics 2017 v1.0 [01.2017] + ACTIVATION Admin 0 2,962 02-05-2020, 06:10 AM
Noregon JPRO Noregon JPRO Commercial Fleet Diagnostics 2016 v2.3 + Activator Thunder 0 2,732 02-23-2017, 03:46 AM
Noregon JPRO Noregon JPRO Commercial Fleet Diagnostics 2016 v2.2 + Activator Thunder 0 4,052 11-30-2016, 06:42 AM
ZZ.Blank Noregon JPRO Commercial Fleet Diagnostics 2016.2 + Activator Thunder 0 2,796 07-25-2016, 08:06 AM
Noregon JPRO JPRO Commercial Fleet Diagnostics [01.2014] Admin 0 5,154 01-13-2015, 05:58 AM
