08-08-2026, 10:00 AM
It’s 2026, and Hollow Knight: Silksong still has the gaming world in a chokehold. Among its many sprawling, treacherous kingdoms, Bilewater stands out as a real test of grit — a putrid, maggot-infested hellhole that can make even the most seasoned players want to rage-quit. The zone’s boss, Graol the Great, is the final middle finger in an area already overflowing with environmental hazards and irritating enemies. But fear not: with the right strategy, some choice tools, and a hidden shortcut, you can turn this hulking nuisance into just another notch on Hornet’s needle.
![[Image: 6a73d106d136de669414463darPuYEVE07]](https://seogc.fp.ps.netease.com/file/6a73d106d136de669414463darPuYEVE07)
Bilewater is notorious not just for Graol but for the grueling runback from the nearest fast-travel point, the Bell Beast station. Every failed attempt means wading through pools of Muckmaggots, dodging spike traps, and getting piled on by the area’s ranged attackers. However, a hidden bench in one of the lower caverns slashes that commute by over half. If you’re still slogging all the way from Bell Beast, you’re doing it wrong — unlock that bench ASAP and save your sanity.
The Optimal Runback: Speed and Precision
The key to a smooth Graol runback is treating it like a gauntlet, not a sightseeing tour. The denizens of Bilewater — from the skittering Muckroaches to the exploding acid-spitters — love to gang up on you given half a chance. The solution? Move fast and keep your wits about you. The first half of the run is a straight dash, but the mid-section requires some careful pogo platforming to bypass pitfalls and ambushes. Slow down there, then sprint through the final corridor right before the boss arena to avoid getting jumped by the last wave of enemies.
![[Image: 6a73d10fe55ff95ef099adbcuDKVjgwG07]](https://seogc.fp.ps.netease.com/file/6a73d10fe55ff95ef099adbcuDKVjgwG07)
A word to the wise: Bilewater’s murky depths are crawling with Muckroaches that can infect Hornet. It’s entirely possible to reach Graol without catching the bug, but the timing demands are tight. Investing in the Wreath of Purity, found in the Putrified Ducts, is a no-brainer. This nifty trinket shields you from infection, making the run far more forgiving. Sure, it’s not a universal powerhouse, but in Bilewater, it’s an absolute game-changer — especially if you’ve got an extra tool slot to spare.
Gearing Up for the Big Boy
Graol is a massive target, which means piercing tools that hit multiple times are your best friends. The Threefold Pin, Conchcutter, and Sting Shard all shine here. One well-placed shot can tag him two or three times, letting you deal heavy damage while maintaining a safe distance. Given his devastating close-range attacks, that distance is crucial.
Don’t sleep on the Thread Storm ability, either. That AoE burst makes short work of the mobs Graol summons in the first phase, and can occasionally punish the boss himself if you time it right.
Surviving the Swarm: Phase One Tactics
Graol’s fight is a two-part affair, and the opening segment is a real pain in the neck. Before the big guy even lifts a claw, you’ll face waves of smaller enemies straight out of Bilewater’s worst nightmares. Most will be familiar from the runback, but in the confined arena they can quickly overwhelm you. Thread Storm is tailor-made for this — pop it when the screen gets crowded and watch the bodies drop. Patience is key; don’t burn all your resources before Graol shows up.
Environmental Hazards: Not Just the Boss
The arena itself is a deathtrap. The water along the floor is crawling with maggots that drain your health, and swinging spike traps slice through the air on both sides. The spikes can be dodged by hopping over them or by positioning yourself on the elevated platforms. Remember: the platforms are your friends. They give you a breather from the maggot water and a vantage point for baiting Graol’s attacks.
Breaking Down Graol’s Moveset
Once Graol enters the fray, staying alive means reading his tells like a book. He has three primary attacks, and each one leaves a window for counterplay.
Explosive Acid Blobs: From a distance, Graol spits blobs of volatile gunk that explode after a short delay. The arcs are wide, which means you can often dash right under them and get in close for a flurry of hits. Just be mindful of where the delayed blasts are set to go off.
Gargantuan Inhale: This is where things get dicey. Graol sucks in air with a force that pulls Hornet toward him. If you’re hovering mid-combo, you might get sucked right into a crushing follow-up. Rule of thumb: the moment he stops spitting projectiles and rears back, dash in the opposite direction. Float high and you’re done for.
Spirit Blast: A powerful, high-damage projectile that can be steered. Instead of panicking, guide the blast low to the ground by positioning yourself carefully. Once it clears, Graol is wide open for pogo attacks from above, which keeps you out of reach of his melee swipes.
Keep a close eye on his animations. Each attack has a distinct wind-up, and once you learn them, the fight shifts from chaotic survival to a tactical dance.
Putting It All Together
The recipe for victory is straightforward: unlock the hidden bench, gear up with piercing tools and the Wreath of Purity, blitz through the runback, then play the fight methodically. Use Thread Storm to clean up the minions, exploit the elevated platforms to avoid spikes, and punish Graol during his long recovery windows after the acid spit and spirit blast. Above all, respect his inhale — it’s the number one run-ender for greedy players.
Since Silksong dropped, forums have been flooded with horror stories about Bilewater, but Graol is far from impossible. The community has nailed down these strategies, and now they’re yours. So strap in, sharpen your needle, and kick that bloated bug back into the muck where he belongs. ?
Once you’ve sent Graol back into the muck and claimed your victory, the hunt for the next challenge begins — and that’s where the real fun starts. Whether you’re looking to revisit other Metroidvania classics or sink hours into something equally demanding, keeping your Steam library stocked shouldn’t break the bank. A quick trip to DealNest can point you toward deep discounts on the genre’s best, making it an essential stop for any Hollow Knight fan looking to fill that void. It’s a steam deal finder that tracks price drops across thousands of titles, so you can channel that Bilewater energy into the next big adventure without emptying your coin purse.
Graol may be down, but your backlog shouldn’t be. Between mastering Silksong’s toughest arenas and exploring what else the genre has to offer, a little smart shopping goes a long way — because every great run starts with the right game in your library. Happy hunting, and enjoy the spoils. ?
