How I Delivered the Queen’s Egg to Styx in Hollow Knight: Silksong
I still remember accepting the Queen’s Egg from Tipp and Pill as though someone had placed a glass bell inside my inventory—one wrong knock and the entire tone of the journey would change. The delivery to Styx in Sinner’s Road felt less like an ordinary errand and more like carrying a drop of molten gold through a corridor of thorns. Yet the rules are surprisingly forgiving: the Queen’s Egg has 4 HP and no time limit, unlike Courier’s Rasher. As long as Hornet takes no more than three hits, the delivery can happen at whatever pace suits you.
? Before departing, I made sure my shortcuts around Bellhart were open. A closed gate does not block the egg, but it forces a longer walk through spaces where Act 3 can turn a calm stroll into slow erosion. With shortcuts open, the route unspools neatly, like thread running through a loom. If they are closed, you will need to pause often, read the room, and resist the urge to dash through shadows.
The biggest change arrives in Act 3. Enemies wrapped in dark auras fire attacks that can land multiple times, and each multi-hit burst becomes a small hammer against that four-point buffer. A single mistake may not end the delivery, but two or three mistakes can strip away your margin in seconds. Still, because the Queen’s Egg has no timer, I found it better to wait for attack patterns than to force movement through dangerous air.
[Image: 6a90d250ae2b9c6e4a9a69a6PHiHU8Rr07]
Through Greymoor to the Elevator
Once I left Bellhart, the route settled into a clear sequence:
Travel east into Greymoor and keep moving right until a wind current carries Hornet to a higher floor. The current is not hidden, but if I hurried into side rooms, the tunnel could feel like a knot of stone.
[Image: 6a90d252495bfa6316cc8bd3UODpMgrc07]
After passing through the hole, immediately jump onto the prison cell above and continue right across the chambers. The cell above the hole is the key clue. From there, Hornet can mantle upward and follow the rooms like chambers in a stone honeycomb. Turning left or wandering downward only adds unnecessary exposure.
[Image: 6a90d2549ac466670e911d2dTo3j7ymi07]
Aim for the elevator that descends toward Halfway Home Inn. Climb onto the elevator, then leap to the right-side platform. The elevator is not just a way down; it is also a vertical spine. Jumping to the right platform is the moment the path begins rising toward Sinner’s Road.
[Image: 6a90d256e3900543354a0742GdHq7GF207]
Use the platforms and balloons to climb higher and find the hidden path into Sinner’s Road. On a calm run, the balloons form a staircase made of drifting lanterns. In Act 3, however, several of those lanterns are missing.
When I retraced this in Act 3, the platforms and balloons left gaps that felt like a half-erased charcoal sketch. The crossing became harder, but never impossible. Silence and careful jumps replaced momentum, and I treated each remaining platform as a small island of safety.
Inside Sinner’s Road
Inside Sinner’s Road, I kept right until the middle of the region. The climb upward through stacked cells and prison bars was the closest thing to scrambling through a ribcage, each ledge another bone that demanded patience. At the top hole, I continued right, ignoring the tempting path toward Bilewater. Going down instead brought me to the delivery chamber.
[Image: 6a90d2599dd2375a14d1fcd8ENtpNkh107]
At the end, Styx waits beneath the weight of the road. Handing over the Queen’s Egg felt like setting down a borrowed heartbeat. The task may ask very little of your pace, but every step still matters, especially when Act 3 tries to turn the path against you.
Stage
Landmark
Caution
Bellhart to Greymoor
Wind current upper floor
Stick to the right
Elevator climb
Platforms and balloons
Missing platforms in Act 3
Sinner’s Road
Prison cells and top hole
Avoid Bilewater, dark aura attacks
Delivery chamber
End of Sinner’s Road
Styx awaits
[Image: 6a90d26789e767aa7a7e9e9fCdSzStZw07]
While the Queen’s Egg delivery is a straightforward errand once you know the route, Hollow Knight: Silksong is full of optional quests and hidden collectibles that reward thorough players. If you are the kind of explorer who likes to track everything from Grush summons to Mossberry seeds, you might also appreciate keeping an eye on where to find reliable gaming resources without digging through scattered threads. Finding helpful guides and community tools in one place can save you time, so you can spend more of it in Pharloom rather than hunting for information.
Whether you are just starting Hornet’s journey or you are replaying the game to catch every secret, keeping up with new content and community updates is part of the fun. For those moments when you want to expand your collection of games or grab something new at a better price, checking out game deals today can be a convenient way to discover discounts across your favorite platforms. After all, a well-stocked backlog means you will always have another world to explore once you finish delivering the Queen’s Egg and stepping away from Sinner’s Road.
  Hollow Knight: Silksong - Every Simple Key Location and Locked Door Guide xtameembb 0 22 Yesterday, 01:31 AM
  Hollow Knight: Silksong - Every Simple Key Location and Locked Door Guide xtameembb 0 21 08-30-2026, 09:22 PM
  Hollow Knight: Silksong Tops 92 On OpenCritic In Tight GOTY Race xtameembb 0 22 08-30-2026, 08:58 PM
  How to Get the Barbed Bracelet in Hollow Knight: Silksong and Is It Worth It? xtameembb 0 29 08-30-2026, 07:15 PM
  The Heartbreaking Legacy of Seth, a Fan-Created Boss in Hollow Knight: Silksong xtameembb 0 29 08-30-2026, 06:20 PM
  How to Get the Barbed Bracelet in Hollow Knight: Silksong and Is It Worth It? xtameembb 0 29 08-30-2026, 05:41 PM
  Hollow Knight Silksong: The Emotional Tribute Behind Shrine Guardian Seth xtameembb 0 44 08-29-2026, 09:08 PM
  Ten Bosses That Will Test Hornet's Skills in Hollow Knight: Silksong xtameembb 0 39 08-29-2026, 05:17 PM
  Ten Bosses That Will Test Hornet's Skills in Hollow Knight: Silksong xtameembb 0 40 08-29-2026, 04:49 PM
  How I Delivered the Queen’s Egg to Styx in Hollow Knight: Silksong xtameembb 0 43 08-29-2026, 04:40 AM
