Hollow Knight: Silksong: Every Ventrica Station Location and Fast Travel Guide
[Image: 6a9cafbf6677d88a001d3d0dpAceQ7oP07]
As players explore the Grand Citadel in Hollow Knight: Silksong during 2026, the sheer scale of the place can sneak up on anyone. There are 9 sub-areas in this one map — and that is if players count the Grand Gate — so getting turned around is pretty much par for the course. Luckily, Team Cherry added Ventrica stations, high-speed tubes that launch Hornet across the Citadel in a flash, much like the Bellway Stations players have already used. The catch? Some of these stations are tucked away, and without enough Rosaries on hand it is easy to walk right past them and forget they exist.
What Makes Ventrica Stations So Useful
Ventrica stations are more than just convenience. They cut down travel time, make Rosary farming routes much faster, and open up shortcuts to merchants and bosses. In a game as sprawling as Silksong, having the right fast-travel point unlocked can be the difference between a smooth run and a long, boring walk.
Below is the full rundown of every Ventrica station in the Grand Citadel, along with the best ways to use each one.
Terminus
[Image: 6a9cafc8876b84a5794a8631umLfJ2to07]
Terminus is the central hub of the Ventrica network, and every other station feeds back into it. To be blunt, there is not a ton to do here beyond resting and making the run back to the main Act 2 boss. Still, it is the backbone of fast travel in the Citadel, so players should unlock it as early as possible.
Memorium
[Image: 6a9cafd15f62ee3c771e7392evicAHIH07]
The Memorium station sits in the top-left corner of Memorium. It is not the flashiest fast-travel point, because the area itself is fairly small. Its main uses are rescuing a giant flea, grabbing the Materium device, and heading toward the Putrified Ducts. Players who want to fill out the Hunter’s Journal can also grind enemies nearby without much hassle.
High Halls
[Image: 6a9cafdad4267821257dc9aeiiq2Gt4507]
Found just before the Forum Gauntlet fight and close to the Sentinel boss fight, the High Halls station is a real gem for anyone looking to farm Rosaries. Players can rest at the bench here, sprint down the long corridor, and wipe out tall guards along the way. In Act 2 there are five guards, and when paired with Grindle’s Thief’s Mark, a single run can net 275 Rosaries. Rest at Songclave, then rinse and repeat until the wallet is loaded.
First Shrine
[Image: 6a9cafe5391a94d40dca4abfIqIVJcjI07]
This station is just above Songclave and sees constant use during missions from the Overseer and the Wishboard. It also provides quick access to the Whispering Vaults and Jubilana the merchant, making it a handy pit stop for errands and shopping.
Choral Chambers
[Image: 6a9caff2f3356f8d0d96ffff6sePITXj07]
Found in the far west of the Citadel, the Choral Chambers station opens up routes to the top of the Grand Gate, Whiteward, and the rest of the Choral Chambers area. Players attempting the Couriers Rasher delivery will pass through here often, so it is worth memorizing. It is also a solid travel point for one of the main Act 3 bosses.
Grand Bellway
[Image: 6a9caffdfda53b07e28ecdc51bfMRGbc07]
Grand Bellway is the workhorse of the Ventrica network. Because it sits right next to the Bellway Station and has a bench, it is perfect for both Trobbio fights and serves as a crossroads. From here players can reach the Whispering Vaults, Choral Chambers, the Underworks, or even the Exhaust Organ in Bilewater. If someone only unlocks one extra station beyond Terminus, this should probably be it.
Underworks
[Image: 6a9cb006723d12c5e2fb2ae2qkbKoY8X07]
After dropping from Whiteward and grabbing the Clawline ability, the Underworks station is the fastest way back to the surface. It is also the closest fast-travel spot for visiting the Architect, whose shop is just a short stroll to the north-east. Whenever players need new items or upgrades, this station is a huge time-saver.
Quick Reference Table
Station
Location
Best Use
Terminus
Central hub
Resting and Act 2 boss runs
Memorium
Top-left Memorium
Materium device, Putrified Ducts, Hunter’s Journal grinding
High Halls
Before Forum Gauntlet
Rosary farming and Sentinel boss access
First Shrine
Above Songclave
Overseer and Wishboard missions, Whispering Vaults, Jubilana
Choral Chambers
Far west Citadel
Grand Gate, Whiteward, Couriers Rasher route
Grand Bellway
Next to Bellway Station
Crossroads, Trobbio fights, Exhaust Organ route
Underworks
Near Architect
Clawline return, item shopping
Final Tips for Speedrunners
Learning how to get around the Citadel in the shortest amount of time is a major part of Hollow Knight: Silksong, especially for players chasing Speedrun achievements. The Ventrica network is not just about convenience — it is about shaving minutes off every trip. Unlock each station as soon as the Rosaries allow, and if a location feels forgotten, backtrack after unlocking an area ability like the Clawline. A few Rosaries spent on travel now can save a lot of headache later. ?️
Mastering the Ventrica network is all about respecting your own time as a player — the less time spent backtracking, the more time you have for boss fights, exploration, and chasing that perfect speedrun. The same mindset applies outside the game too: players who love optimizing routes tend to appreciate getting the best value for their gaming budget.
If you are looking to pick up Hollow Knight: Silksong or expand your library after finishing the Citadel, it is worth checking out the game deals today on DealNest. That way, you can spend less time hunting for savings and more time exploring everything Pharloom has to offer.
  Hollow Knight vs Silksong: My Honest Verdict After Finishing Both xtameembb 0 30 Yesterday, 08:44 AM
  Hollow Knight: Silksong: Every Ventrica Station Location and Fast Travel Guide xtameembb 0 35 Yesterday, 12:23 AM
  Hollow Knight vs Silksong: My Honest Verdict After Finishing Both xtameembb 0 31 09-06-2026, 10:24 PM
  How I Beat Trobbio in Hollow Knight: Silksong Act 2 xtameembb 0 38 09-06-2026, 07:32 PM
  Silksong: Wispfire Lantern Location and Father of the Flame Guide xtameembb 0 32 09-06-2026, 01:44 PM
  How I Got Hollow Knight: Silksong's Cursed Ending While Bearing the Twisted Bud Curse xtameembb 0 42 09-06-2026, 05:12 AM
  Silksong: Wispfire Lantern Location and Father of the Flame Guide xtameembb 0 41 09-05-2026, 10:00 PM
  My Courier Nightmares and Triumphs in Hollow Knight: Silksong xtameembb 1 64 09-05-2026, 09:15 PM
Last Post: shehnaazkhan
  All 18 Spool Fragment Locations in Hollow Knight: Silksong (2026 Guide) xtameembb 0 51 09-05-2026, 04:33 PM
  My Courier Nightmares and Triumphs in Hollow Knight: Silksong xtameembb 0 52 09-05-2026, 12:53 PM
4 Guest(s)
