4 hours ago
When I first faced the Savage Beastfly inside the Chapel of the Beast, I had a rough time simply because it tracks your movement while flying and immediately calls in three extra enemies to pile on pressure. In 2026, with the latest Hollow Knight: Silksong build, the rematch tied to the Bellhart quest still surprises many players, and the arena is honestly worse than the first encounter. I have tested this route several times, and the good news is that a specific loadout can end the fight in under a minute if you set up properly.
Prerequisites and Quest Start
Before you can accept the rematch wish, I recommend confirming three things:
You have defeated the Savage Beastfly inside the Chapel of the Beast.
You have progressed through the second Act.
You have defeated the Cogwork Dancers.
Once those requirements are met, head to Bellhart and check the board for the Wish. Accept it. Then travel to the Far Fields Bellway Station. Tracking the beast from here is possible, but it takes time and offers no extra rewards, so I always skip the tracking step.
Reaching the Rematch Arena
From Far Fields Bellway Station, take the left passage. Then head down, and after that move right. You will eventually enter the same section as the Four Chorus. That is where the Savage Beastfly rematch takes place.
The arena here is more dangerous than the Chapel because lava surrounds the sides, and the boss can destroy platforms when it performs its slam-down attack. Keep this in mind before you trigger the fight, because losing a platform at the wrong moment can push you into a very bad position.
Recommended Loadout
This is the setup I use after many failed attempts with other tools. Bring the following:
Tool
Why It Works
Sting Shard
You can lay these out before the fight begins. If the boss touches them, the burst damage is huge.
Curveclaw
This gives you a safe long-range option while the Beastfly is flying around.
Pollip Pouch
It adds Venom to your tools, so every Sting Shard and Curveclaw hit becomes much more effective.
The key is preparation before the fight starts. With the Pollip Pouch adding Venom, your placed Sting Shards can deal so much damage that the encounter ends in less than a minute. I usually place several Sting Shards near the centre before triggering the boss, then immediately switch to Curveclaw for follow-up hits.
Fight Strategy
? Pre-place Sting Shards: Before the boss activates, scatter a few traps around the safe platform area. The venom bonus makes a huge difference.
? Stay mobile: The Beastfly tracks your position while flying, so standing still is a death sentence. Keep moving toward undamaged platforms.
? Watch the lava: Since lava covers the sides, never dodge blindly toward the edges. Try to keep the fight near the centre until a platform breaks.
? Punish the slam: When the boss goes for the slam-down attack, it can destroy a platform. Wait for the animation to end, then counterattack quickly before it returns to the air.
? Clear the adds: The boss summons three enemies at once. Kill them quickly with Curveclaw so you do not get surrounded while trying to avoid lava.
After the Beastfly dies, pick up the Horn Fragment. Then return to the Bellhart quest board. Completing the Wish will reward you with a Mask Shard, which is required to increase your maximum health.
This is one of those Silksong quests that feels unfair at first, but the right tools completely change the fight. I have not found a faster or safer method than the venom-backed Sting Shard opening. Even if you miss a trap or two, the Curveclaw gives you enough range to finish the job without standing in the lava. Good luck with the rematch, and keep moving.
That same preparation mindset carries over beyond the game itself. Just as you scout the arena and place your tools before the Beastfly fight begins, it pays to plan your purchases before you commit. Silksong's DLC, a better controller, or even a Steam gift card can show up at a much lower price if you are willing to wait for the right moment.
Instead of refreshing store pages every day, you can let this price tracking tool watch the price for you. Set an alert, keep playing, and you will get notified when the price drops—so your wallet lasts as long as your determination.
Recommended Loadout
Tool
Why It Works
Fight Strategy
